Backcountry Pilot • Rusty Water in fuel tank?
25 postsPage 2 of 21, 2
Re: Rusty Water in fuel tank?
kg wrote:
Draining the tank can be dangerous.... don't do it in an enclosed hangar!
A friend who managed the flight school at the time, maybe 5 or 6 years ago, told me about a mechanic at Bowers Field (Ellensburg) WA who was draining the fuel tank of a high wing aircraft inside a hangar. The hangar door was open. A static spark from a dropped cloth was all it took to toast multiple aircraft and a hangar or two.
Maybe pulling your plane out of the hangar might be something to consider.
PapernScissors offline
Aircraft: Cessna 172
I have that filler neck kit on my 170 that MTV referenced. It is a must have. Seems like it would be easy enough to make yourself. I'll look for some pictures
Alaskan Tin Can offline
Aircraft: C-170B
First, drain fuel via the gascolator. Second, best to do outside. Third, best to do via a piece of tubing to avoid slop. And finally, connect the airplane at the gascolator to the bucket (you are using a metal bucket, right?) with a bonding wire.
Or make sure the tube is submerged in the fuel in the bucket.
Aryana offline
Aircraft: 1955 Cessna 170
Here’s a picture of this type filler with the mod:
Note that the “moat around the filler is covered. No little storage container to contaminate fuel. This would be relatively easy to fabricate, and should be a minor mod.
