ANY RV is an excellent choice for just about any mission short of weedwhacking through tall brush. My RV8 could handle reasonably smooth sod strips and packed dirt no problemo. This was with standard 5.00x5 tires. I've seen 6.00's put on an RV8 and tucked into standard wheel pants, you could hardly tell they were there. The RV is just an awesome airplane, and I really miss my RV but I needed more utility value in an airplane. Yes, you can stuff a decent amount of gear into an RV, but you'll always be traveling "light" vs. the standard Winnebago load the bush planes can haul. CG is more sensitive with the RV too. You have to consider when you build it, how to suit empty CG to your intended mission...heavy engine/prop up front for max loading capacity, but always have nose up trim while solo? There is no right answer.
The -9 is a SUPER design. I've flown a -9A with a Subaru engine up front and it was mighty smooth. The ship stands tall and with a three blader up front the ground clearance is pretty good. The nose gear struts on the -A RV's have had some "issues" over the years. Several have folded under on even smooth pavement. I attribute it to mostly pilot error, but the struts seem undersized to me as well. I would not consider any nosewheel RV for a steady diet of rough strip operations. Put 6.00's on a -9 (tailwheel) and you've got a very capable machine. An O-320 with three blade (or two, but with less ground clearance) composite prop, built LIGHT will be one helluva plane. The wing on this airframe is amazing. It's got a pretty thick airfoil but is still very fast. The higher aspect ratio vs. the other, short-winged RV's seems to help in climb and reduction of induced drag.
If you want basically the same airplane (but with only a nosewheel option) the RV-10 will haul four plus decent bags at 165 kts with a Lyco six banger up front. I have a completed empennage/tailcone kit for one. (for SALE $3k)
The latest, matched-hole kits from Van's are absolutely superb. You simply can't build them crooked.
Yes, I like them.
Probably why I have at least a half dozen referral checks from them.
Brian Denk
RV8 N94BD builder/pilot 450 hrs.
Still really enjoying my Skywagon but you never forget your first love.
