mtv wrote:I used both Globalstar and Iridium phones heavily for a number of years, working in northern AK (as in north of N60), and the Iridium phones were extremely reliable, whereas the Globalstar system was essentially useless... with the Globalstar phone system, dropped calls are the norm, due to poor satellite coverage. After a few seasons trying to use the Globalstar system, we gave up on them, and used nothing but Iridium phones.MTV
idair wrote:Iridian will bounce your signal around between their satellites "peer to peer" until it reaches the home station, of which there's only one or two...
...my guess is this was primarily done as their largest client was the DOD, and it wouldn't be acceptable to be in a war zone and have to hand off your call to a ground station within 600 miles. This way that voice signal can backhaul across the world in space and no nation-state can shut down (or tap) a ground station...
denalipilot wrote:idair wrote:Iridian will bounce your signal around between their satellites "peer to peer" until it reaches the home station, of which there's only one or two...
Yes. Strategic considerations are why the primary Iridium ground station is located in Hawai'i.
As a side note, be aware that all Iridium calls are treated as international calls. This means that 1-800-WX-BRIEF does not automatically connect you to a FSS in your area. This may or may not make a difference in the lower 48 with Lockheed Martin running everything, I don't know- but here in Alaska where we still enjoy local weather briefing and flight services, you really need to carry and use the local exchange numbers to call FSS on an Iridium phone. I learned this the hard way years ago when I got a FSS guy in Long Island who claimed he could close me out, but half an hour later my wife gets the dreaded middle-of-the night call about my flight plan not being closed. Fortunately my second call had been to close out my wife-plan.
-DP
o4abushmaster wrote:Just curious, what are the rates/plans/minutes and whatever other considerations there are with an Iridium. I see that rentals are available, are they that expensive to buy? Are there some models of the Iridium that are better than others?
Thanks in advance.
Users browsing this forum: No registered users and 21 guests
