Backcountry Pilot • SatelliteViews.net
SatelliteViews.net
9 postsPage 1 of 1
SatelliteViews.net
I found this site last night. Looks interesting. I did a quick search, but didn't see it on any threads here.
http://www.satelliteviews.net/cgi-bin/g ... pe=airport
http://www.satelliteviews.net/cgi-bin/g ... y=&l1000=y
Re: SatelliteViews.net
Good find Gump. Thanks.
Little bit grainy out in the bush though!
denalipilot wrote:Little bit grainy out in the bush though!
It always is.... :shock:
Cool reverse approach to the Google maps usage: Index points of interest, then show them on the map, vs using the map as the starting point.
To anyone trying this, start by clicking "home" then choose a state, then "airports." Gump's links are specifically for Nevada.
I discovered this site not long ago, and used it to pimpoint a grass strip I overflew about 5 south of a regular airport. Kinda easier to use that airport as a starting point, as opposed to a lat/long or just zooming down from a large scale map. The resolution was pretty good where I looked -- mainly Skagit County WA.
I did a search for airports nearby. a few of them don't exist anymore. I did find this interesting one. It's an ag strip and it has a marriage proposal cut into the grass. You can clearly see " Amanda, will you marry me? " Perfect letters too. Very sweet.
http://www.satelliteviews.net/cgi-bin/g.cgi?fid=998047&state=NC&ftype=airport
obxbushpilot offline
Aircraft: C 172 Tailwheel
While scoping out this site, I discovered a new to me feature of AirNav. Private strip listings.
http://www.airnav.com/airports/us/NV?use=R
Seems the "?use=R" at the end of the link for the state opens it up. I'm sure it's in the advanced directions somewhere, but I was too dumb to find it till now.
In searching SatelliteViews.net home it goes all over the U.S, just pick out your state and go to Airports .
182 STOL driver offline
Re: airnav........click "airports", then click "browse by state", then go to the bottom of the page & click "private use", then click the state you're interested in. FWIW airnav shows 125 public use airports in Washington,and 238 private ones.
I've been using airnav for years & while I've looked up individual private strips before, I never knew you could browse them like this. Thanks for pointing out this feature, Gump.
9 postsPage 1 of 1
