The savage has a backseat that is held in by two 3/16 bolts. That's it. Super light weight seat and hardware. So I planned on using the existing mounting locations for my platform.
I am using 3/4 in aluminum C-channel for the attach points to the fuselage. You can see it in the bottom of the next pic.
Last night I welded up the 1/2" welded steel square tubing frame that will support the load.
The center supports are 1/2" flat stock.
The bolts will be replaced with quick pull pins.
I will attach the steel to the aluminum with rivets. (I think. Maybe self tapping screws. We will see.)
The platform itself will be .25" kydex. I will try to mold out a relief section for the portion of the stick that will be elevated above the level of the platform. The Kydex should be here in a day or so. I am going to install u bolts for lashing points on the platform perimeter.
I'll post more pics as I progress.
(Edit: the tubing and flat stock are 1/2" not 3/4)
However you do it it will be much more functional then that fabric bag back there now.
