I have a question to pose here:
I have heard about an issue with Scott tailwheels and that in certain circumstances they can "lock" backwards due to improper wear internally creating a notch on the reverse side of what I assume to be the arm assembly. When this notch is made the spring catches it causing the tailwheel to lock "backwards".
I am trying to do some research on this and I am not coming up with alot at all. If this is a known issue is there any ADs out on it, or nay tribal knowledge on how to recognize/prevent this from happening short of dismantling for inspection?
Thanks for any info!
luckily no damage ensued as a result (LUCKY!)
