asa wrote:Probably not the pawl itself. More likely it's the U-ish shaped piece of spring steel. Sometimes you can just bend it back, or you can buy a new one. Also the housing could wear a bit where the spring is supposed to catch. If it's been years since it's been apart, you might benefit from a rebuild kit from Airframes Alaska.
hotrod180 wrote:Those Scott t/w videos by Steve Pierce are great,
but keep in mind he is rebuilding a 3200 tailwheel--
a 3400 is slightly different.
Sounds like a t/w teardown is long overdue--
I tear mine down every year to clean, inspect, & lube.
Sounds like your compression spring is not properly engaging the notches in the steering arm.
You can bend the spring arms outward to engage better.
Be sure & dress the ends to eliminate any burrs or whatever.
You can also reshape the notches in the steering arm with a little file.
Or you can just buy new parts.
Unfortunately the manufacturer is pretty proud of all that stuff & charges accordingly.
hotrod180 wrote:Sounds like a t/w teardown is long overdue--
