Backcountry Pilot • SCOTUS win for GA too?
34 posts • Page 2 of 2 • 1, 2
Re: SCOTUS win for GA too?
mtv wrote:
NineThreeKilo wrote:
contactflying wrote:If the engine makers and insurance would cooperate, we could go back to from the pump gas. The vapor lock problem could be solved by putting the summer additive in all year around. Political, yes. The job of politicians is to make those kinds of deals. There should be some economy in all using the same gas.
Anyway that is what worked for me as long as I owned airplanes. With low wing, I kept the boost pump on.
I thought the vapor lock was due to ethanol
Also thought even w/o ethanol pump 91 wouldn’t jive with FI big bore?
You can readily buy 91 octane auto fuel that contains no ethanol. At least three stations that sell it here in Bozeman. The problem with ethanol in aircraft is that some components in aircraft don’t deal well with ethanol.
But, the REAL problem with leaded gasolines, as I see it is this:
There is precisely ONE facility in the WORLD that refines and produces tetra ethyl lead, which is used in 100 LL. One facility. And, that facility is located not in the US, but in Britain. So, we little airplane owners have a huge stake at present in keeping that facility open.
But, what happens when some group of loonies in Britain decide to shut that abomination of a plant down, to eliminate this horrible pollutant from our/their atmosphere? Simple answer: The end of 100 LL avgas. Period.
And we have no control/influence whatever over that facility.
THAT’S why we need an alternative to 100 LL. If you have been watching what happens in the world these days, it’s not much of a stretch to consider. And there are and will never be another facility to produce the stuff.
Could one mix something like tetra ethyl lead with non ethanol 91 mogas and be good to go in a fuel injected big bore?
https://www.parchem.com/chemical-suppli ... 42235.aspx
My IO520 runs just fine on 91 octane. The main issue is the potential of vapor locking in the FI lines, most likely at high altitudes. The engine itself feuns great on it as they are low compression for the most part.
I don't know about high compression and fuel injection, David. All station gas worked for low compression and carburetors. Round engines and low compression opposed engines with carburetors worked well except low winged Cherokees and CallAirs would quit if you didn't keep the boost pump on all the time. I flew a CallAir that I had to wiggle the defective fuel pump switch in the field from time to time because the mechanic/owner would write up "unable to duplicate." Since I never actually ended up landing in the crop, it didn't get fixed as far as I know. I always wondered about mechanics who had been in Alaska for years back then. He not only ran gas station gas but gas station oil as well. That was when it was cheaper to rebuild than insure and pitot tubes were cut off in prep for new fabric.
The sooner we eliminate lead, the better, even if it comes with short term pain. Said as the owner of a fresh and costly zero timed 520.
Tetraethyl lead is as bad as they say. There’s likely not as much of it settling around airports as they say, but there is no question it does nothing good for our health and the surrounding environment. It also isn’t as hard to eliminate as many in GA circles try and make it sound.
Lead is the source of my biggest misgiving about GA flying, I went through a bout of lead poisoning as a younger man and it’s horrible. Worst part is it never really leaves you, it just accumulates in your body. I’ll be the first lined up to pay more for unleaded gas.
Ardent offline
Aircraft: A185F
Ardent wrote:The sooner we eliminate lead, the better, even if it comes with short term pain. Said as the owner of a fresh and costly zero timed 520.
Except test reports of lead from old white rich guys' toys from places like KRHV are bogus.
Ardent wrote:Lead is the source of my biggest misgiving about GA flying
Maybe you picked the wrong hobby? I am sure there are less stressful activities you could take up like scrap-booking.
F that
C180_guy offline
F that
About the only thing I really don’t like about this web forum is the propensity for some regulars to insist on getting insulting.
If you can’t act like a civil adult in a conversation, maybe it’s you who should take up scrapbooking.
Good grief!
F that
Good grief!
I think C180_guy is just proving the lead-crime hypothesis.
"At the behavioral level, exposure to lead has been observed to cause increases in impulsive actions and social aggression."
I’m sure without the refraction of the internet C180 is a great guy, this format of discussion through little typing portals unfortunately just does strange things.
There’s also the unfortunate view many take on change, that it is always for the worse. Much is for the better, but that always get less press just as how word of a good haircut spreads far less than of a bad one.
Removing lead from fuel is one of the good ones and will expand the future of our favoured pursuit rather than limit it.
Ardent offline
Aircraft: A185F
Somewhere in my guidelines for the site is an important rule about not being a dick. Only so many infractions before one gets tossed on the old dicks pile.
Fortunately, I have immunity.
Ardent wrote:I’m sure without the refraction of the internet C180 is a great guy, this format of discussion through little typing portals unfortunately just does strange things.
Well thank you Ardent, my wife and dog think I am! Just back from flying my high compression lead-burning Continental. While lead may have deleterious properties, banning it based on a bogus report from the Santa Clara County supervisors is wrong. And, when it comes to the cost of any 100LL replacement, I agree with what some have posted on the BT 100LL mega thread on price - don't give an inch.
C180_guy offline
Just like all the enviro extremists it’s all another YOU paying more because…uh…reasons..that’ll save the what the fuck ever du jour
GTFO
Are you going to document our journey to china and India to combat the much much more major pollution? Please link the live stream
Well, this thread has been sent down the shitter. Oh well.
NineThreeKilo wrote:Just like all the enviro extremists it’s all another YOU paying more because…uh…reasons..that’ll save the what the fuck ever du jour
GTFO
It's become more and more difficult to find anything likeable about you.
To anyone else who wants to toe the line with political but somewhat-relevant-by-a-thread connection to flying: please don't. Please respect that I made the no-politics rule for a good reason, then go off to Facebook.
Thanks.
