Tue Jul 30, 2019 12:18 pm
For the extended baggage, I just sewed up a webbing cover with tangs that screw into the four 10-32 rear bulkhead mounts for the original rear plastic bulkhead you'll never use again. I use knurled finger screws for the bolts. It takes about a half hour to shop on amazon for the tangs (with strap loops to adjust the webbing, ones that are rated for at least 150# each), and webbing rated for some large number like 500#, and another hour to sew it up on an industrial machine. You can also just get a speedy stitcher and just put several stitches in the middle of the webbing crosses instead of the seat belt grade stitching from a machine. These threaded points are pretty beefy in my E model. I also added four 1/4-20 bolts with fender washers for pullout resistance and locknuts for the floor, but I've never used them.
For hauling around stuff to help on landing, the aircraft cover, plugs, drivers, wrenches, spare screws, small ratchet set, qts of oil, rags, tie downs, small sleeping bag, first aid, and food/water, etc, it takes up about 1/3 of the extended baggage area at the rear. This is enough to make a difference during the landing when solo, especially with the trim set nose down a ways. When I'm actually camping somewhere I need to worry about the nose gear, usually the most of it fits back there to get up to the 50# limit, and the rest of the stuff add up to make it handle more normally. But when light, I use quite a bit of nose down trim, and roll it the rest of the way down rolling out to help with the weeds.
I also add the small bumper on the front strut to keeps things from settling down too far into the grass where needed.
