Backcountry Pilot • Setup to take videos?
26 postsPage 1 of 21, 2
Some info on how to actually TAKE videos from inside the plane would be great cameras, mounts, settings, etc.
Thanks
airprakken offline
Randy
TU206 with semi-big tires and VG's
I don't claim to be an expert, but I've learned a few tricks. Here are some tips I posted before the JC fly-in.
Video Tips-
1. Mounting: I've had pretty good luck shooting video by mounting the camera to the dash or to a fuse bar. Even an inexpensive digital still camera (that takes video) mounted to the dash with stick-on velcro or duct tape can work well. Press the record button in the pattern and forget about it until you're on the ground.
Simple mounts can be purchased from most camera shops or even REI, but be sure to secure them to minimize vibration.
2. Focus: If you can, put it on manual focus and set to infinite focus to prevent it from focusing on the windscreen.
3. Vibration: some hard drive cameras get upset by the vibration. If your camera has the option, record to a solid state memory stick/card.
4. Smashed bugs: clean the windscreen.
The windscreen can be the weakest link in this process. Even if your camera is super high-end, things can look pretty crappy when you're shooting through a dirty or scratched piece of plexi. I don't have any experience mounting a camera outside of the airplane, but there are lots of obvious places to mount one and most camcorders come with remote controls that you can use to start recording.
chrisg offline
Airstrip Database Manager
Chris
http://www.shortfield.com - Backcountry Airstrip Database
https://discord.gg/HNHKeDE - Groundfall - Bush Flying Video Game
Re: Setup to take videos?
airprakken wrote:Some info on how to actually TAKE videos from inside the plane would be great cameras, mounts, settings, etc.
Thanks
For a cheap and ghetto route. I just picked up a "ClampPod Pro" (about $20) at the local Ritz camera shop and tried it for the first time this weekend. I was able to attach it to the seat back and used the shoulder straps to help hold it in place. It didn't bounce around nearly as much as I would have expected. No more than a passenger would have. It did help to have a Canon S5 with the directional view screen.
Big downside is that I don't have my camera readily available for snapping shots as I'd have to unscrew it from the mount.
Video editing software would be nice to have. Any recommendations would also be helpful.
GroundLooper offline
BCP Poser.
Like I said, I've had some decent results by just attaching the camera to the dash with velcro. It's often better than when a passenger holds it because it moves with the aircraft. A quick release plate available from any camera shop (etc.) allows you to quickly remove the camera for still shots, etc.
Here is what I've done in the past:
1. Get some wide self adhesive velcro pads available from a hardware store.
2. Stick once side of velcro to your airplane dash (it shouldn't cause any damage).
3. Buy a "quick release camera plate" ($10-20 dollars) and stick the other side of the velcro to that.
4. Screw the other side of the quick release plate to your camera.
Here is an <a href="http://www.shortfield.com/index.php?option=com_content&task=view&id=23&Itemid=50&snum=19631.*A&locid=05S&loc=VERNONIA%20AIRFIELD&vw=5" target="_blank">example video</a> that I shot that way several years ago. It's relatively steady. Please reserve your comments about the approach and landing. :)
chrisg offline
Chris
Dark clothing is good- less reflection on the inside of the plexiglas that way
After watching that video again, it occurred to me that I might want to qualify my choice of examples. As you can see, the airplane is moving around a lot, but the camera remains pretty stable, and there isn't too much vibration. Pretty good for velcro on the dash. Also notworthy: the camera was a crappy old DV tape model and was about the size of a fat brick...which may have helped with stability.
chrisg offline
Chris
jmtgt wrote:Pictures, we need pictures of these set ups! :)
I agree -- that would be great.
Also, any velcro tape I have seen would put permanent glue stuff on the plastic. I don't really want to do that to my plane. Has anybody used some "C clamp like thing, possibly padded" on the dash brow?
airprakken offline
Randy
I'm new to this forum but I've been lurking for awhile. This topic seemed like a good thread to get "my feet wet" on so this is my first posting.
On the 206 I used to own I mounted an inexpensive video camera (this was a small fixed focal length camera only (i.e. no storage capability) originally designed to sit on top of a computer) on a bracket which I fabricated & mounted to the wing strut with hose clamps. This way I did not risk losing or damaging a relatively expensive camcorder.
The camera weighed about 6oz's & required 12v to operate and had a single video output which I ran to my camcorder (a rather ancient one which records on miniature tape cartridges) in the cockpit. The set up worked great, I had a virtually unobstructed view forward (except for the arc of the prop and a small piece of the cowling). I plugged the audio output of my intercom into the audio input of the camera thinking I could narrate the film; unfortunately there was an impedeance mismatch and the audio quality stunk.
To turn it off/on I just put a switch in the 12v power line. I powered it off of the cigarette lighter (also used this to power the camcorder inside the a/c).
Videos came out great although if you pointed the camera at the sun it took awhile for it to recover :) I didn't have any vibration problems, perhaps because when I mounted the camera to the bracket I used a rubber "biscuit" between them.
Best of all, the unit required no attention once I turned it on..you can concentrate on flying, not futzing with the camera.
WrenPilot offline
Wren 460 - Ken Foote
airprakken wrote: Has anybody used some "C clamp like thing, possibly padded" on the dash brow?
I looked at doing something like that on the 150. It might work but it might also crack the dash. Mine was already cracked a bit so I was worried I'd just make it worse.
BCP Poser.
WrenPilot wrote:On the 206 I used to own I mounted an inexpensive video camera (this was a small fixed focal length camera only (i.e. no storage capability) originally designed to sit on top of a computer) on a bracket which I fabricated & mounted to the wing strut with hose clamps.
That reminds me...I've also thought about just getting one of the 'high def' USB web cameras and using my laptop to record the video. I can't say what the quality would be like.
chrisg offline
Chris
I also use Velcro on my dash, and plug my intercom into my camera. I use manual on the camera and set it on infinity. I don't have a picture of this setup. I have plenty of videos here if you haven't seen them.
www.youtube.com/skybobb
skybobb offline
Will Rogers 1879 - 1935
I have been wanting to take good video while flying for a long time. I tried sticking my camcorder to the dash by a variety of methods but always ended up with excess vibration. I went all out and called a company called xtreme recall which makes bullet cams for many high end sporting purposes including the reno air races. They made me a custom setup that I can either mount inside the plane or stick on the outside of my headset for a first person view. Call them and ask for Sargon, he will set you up with a custom built system made for exactly what you are trying to accomplish.
Renegade offline
Big fish, Beavers, and Bears!
http://www.alaskarainbowlodge.com
I use a RAM Mount that I stole from my GPS. I had to buy a ball for it with the standard camera/camcorder thread. I think the ball was about $12 bucks, and the mounts can be found for ~$30. The great thing is it clamps on any cockpit bars, is free of vibration, sturdy, can be articulated, and even handles aerobatics well.
Here's a few pics:
Here's a video with a bit of footage that uses my mount:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/PHzwdJJtIfY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/PHzwdJJtIfY&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
sticknrudder offline
Aircraft: 7GCBC
C182
J-3
sticknrudder:
I am going to give your mount a try...looks like it will work for me.
HC
Sticknrudder..............
Great video.......what are you using to edit everything?
Hafast offline
Hafast wrote:Sticknrudder..............
Thanks! I put it together in Adobe Premiere Pro... kinda klunky and slow software.
Chris
Aircraft: 7GCBC
C182
J-3
I've been trying to use Roxio, but it's been kickin my ass.
It ain't easy being retarded.
Hafast offline
Here's my latest attempt at making a video as good as the rest of you guys..........I'm working on it!
The first part is from an Oregon Scientific digital camera mounted on the pitot tube and it's kinda dark. The second video is from my Sony digital tape camera mounted on the v-brace above the panel.
<object width="400" height="302"> <param name="allowfullscreen" value="true" /> <param name="allowscriptaccess" value="always" /> <param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=1649104&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&group_id=1986" /> <embed src="http://vimeo.com/moogaloop.swf?clip_id=1649104&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&group_id=1986" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="302"></embed></object><br /><a href="http://vimeo.com/groups/1986/videos/1649104?pg=embed&sec=1649104">Landing At Redcreek And Payson Arizona</a> from <a href="http://vimeo.com/user656853?pg=embed&sec=1649104">Hafast</a> on <a href="http://vimeo.com?pg=embed&sec=1649104">Vimeo</a>.
Hafast offline
To prevent the camera from hunting focus (and as a result getting nice sharp images of bug guts on the windscreen) preset the focus to infinity. Don't forget to clean the windscreen in front of the camera before departure. Preset the zoom to include the cowling in order to provide a frame of reference for the viewer. If your video camera has exposure adjustments it's better to use a slower shutter speed to that the prop doesn't look stopped. A polarizing filter can make the sky 'pop' by making the blue sky darker in comparison to the clouds. It can also reduce reflections from the plex. Wrap the camera and mount with black velvet fabric to further reduce reflections.
J Michael offline
One of the great regrets I have from nearly 40 years of flying in some fantastic places and projects is that I took very few photos, and no videos.
There's really no excuse for this, even forty years ago--I was just lazy. After all, Noel Wien carried a 4X5 camera with him almost everywhere he traveled in the earliest day of Alaska aviation.
I was just lazy, I reckon.
But, with today's technology available, there's even less excuse not to document things from the air, and airmen in action.
Good on you guys for getting it done.
