maules.com wrote:A similar thread is taking place on maulepilots.org and here is one of my posts based on familiarity with your plane.
On a Maule, I dont use pressure, I use bulge which is dependant on load and density altitude.
Starting with 8.50s for normal use on a Maule, the outer rib is barely contacting the tarmac at about 20psi, Ive run them at 12psi but my guess is that 14 might be better. You dont want to wack the rim on a rock.
Blimp tyres are much stiffer so 12 or even less should be good but again I eyeball.
If pressure is too low, a lot of drag on the ground is induced.
These were originally built as the single castoring wheel under a blimp when tethered at the mast and thus were tso'd.
If the hubcap screw holes happened to go all the way through the rim, a sharpened longer screw could protrude into the tyre bead a quarter inch and the tyre will not slip at low pressure.
Make sure the calipers are on the front so a squeeged tyre at inside bottom cannot grab the caliper.
maules.com wrote:GW26" and GY or Mc can be held from slippage via extended screws in hubcap holes.
Pro-active prevention is the name of the game.
