contactflying wrote:
The advantage of flying on a tight budget is that you get to fly low powered airplanes. In low powered airplanes, you learn to fly the wing and use natural energy like ground effect, gravity, ridge lift, and thermals.
Gravity thrust will make up for the vertical lift lost in the turn.
+1
There have been many times in my own mountain flying experience (which is
way different than most others here) when lowering the nose in a turn was 100% necessary to maintain a tight turn radius, and more importantly give you additional airspeed you could convert into "sideways lift" to clear the rocks. Enough vertical room to lower the nose was very frequently the only emergency safety margin available when you're flying around 12,000 foot rocks at wingspan distance in gusty afternoon lift at 1.1 Vs. For the
most part, horsepower and lift fade away with altitude but gravity is still putting out it's rated thrust.
' far as I'm concerned, rubbing nickels is an integral part of aviation in many areas. There are of course many times and places where you have to spend money to do it right, or do it at all. But there are just as many places IMHO where finding another way to skin the cat teaches some valuable skill or thought process.
In that kind of situation in your video, it's likely that the condition and health of that particular 150 makes a big difference versus another 150. Well... that and
removing the right seat
