Backcountry Pilot • Show Us Your Before-and-After Mod Pics
30 postsPage 1 of 21, 2
This thread’s for your before-and-after aircraft mod photos, big or small.
Whether you reworked the panel, added bush gear, or just swapped a flap handle, let’s see how your airplane’s changed.
Drop in a few details to help other pilots:
What’s your aircraft?
What changed?
What did you learn (or wish you’d known) before starting?
This is an open, ongoing thread. Add to it anytime you wrap up a mod or help someone else with theirs.
Class E offline
Re: Show Us Your Before-and-After Mod Pics
Before:
After:
Conclusion:
Pros: lighter. Lost a lot of weight, recovered some useful. Left side door is nice.
Cons:
Many. Slightly slower cruise, less resilient over rough surface. Less comfortable on my back overall. 1/10 would not perform this mod again.
Is your Pacer still apart, and (I assume) down at Steve's?
The before pic looks like it was a pretty darn nice airplane,
what prompted you to tear into it?
hotrod180 wrote:Image
Logistically it was getting harder and harder for Z to fly out here commercial for a week or so once a year to get anything really accomplished on the project. So the decision was made to move it to Minnesota.
Modifications to the airframe included extending the skylight to our long version, weld on float fittings and installing both left and right seaplane doors. With as much fabric that was removed to do those mods it became apparent that re-covering the entire airframe was just as easy as patching what little fabric was left on it. Besides, the fabric was well over 30 years old and it sat outside for years. Once the fabric was off we discovered some corrosion in the window frames that needed replacing and a few other minor issues that were best fixed with the fabric off.
Anyways, that all I can say about it. Z is still keeping me in the loop as far as advice and general BS chat. :D
--Brian
Brian-StevesAircraft offline
Pavement scares me..........
Dad's SPOT page
Sick of lying upside down dropping things on my face. Love experimental.
And note one of my favourite features of my Cub, the roadsign aluminium on the far side of the bootcowl.
I've come a long way with the Cessna 205 I picked up in 205!
Cessna N8332Z when picked up Jan 2018
Panel 2018
Interior 2018
First panel overhaul left side done July 2018
Rainier in the back, big tires & VG's
Interior post 2018
piperpainter offline
Aircraft: C-205
Was Backcountry Mooney M20C
In 2020 I had a prop strike due to sinking into the sand. I rebuilt the engine and redid all the electric along with adding a JPI EDM 900.
in 2024 I added a sportman STOL cuff
in 2025 a rim fell off a shelf and damaged my elevator. I ended up down a rabbit hole and discovered some issues with the stab, so I ended up rebuilding it entirely. That was fun..... Then....I wanted to increase my pain. So I stripped the plane down to bare metal.
Panel 2021
in 2024 I installed the sportsman
stab rebuild
stripped down mostly
Aircraft: C-205
Does this scream Mooney 2.0 ?? haha "Moonboy!" She's red and black! And I love it. New larger N numbers coming when I get the N number change completed!
Painted!
July 2025
Aircraft: C-205
skyward II offline
skyward II wrote:
I saw the Bearhawk Patrol photos you posted then deleted. It looked great.
Is this your version of disappearing messages so “they” don’t find you in witness protection after all these years?
Brian-StevesAircraft wrote:[
--Brian
Brian will always be my primary mechanic no matter where I am in the world 8) But sometimes traveling home to work on stuff stretches the timeline out to an unacceptable length. It's nice to have the project in my own hangar where I can crack the whip on my own back.
Totally off topic... but every time I see a 205 or P206 I think Cessna would do well to re-introduce that airframe, especially now that all the 135s and missionary groups have moved on to bigger and better things. I seriously doubt many commercial operators are buying the H.
CParker offline
Aircraft: 1979 TU206G
No before pic, but I'm pretty sure everyone know's a cessna cowl looks like. Making progress on fitting this panel to finalize my oil cooler relocation. I'm really excited to see what it does for #5 and #3 CHT. I need to do a little bit of fiberglass work where a couple of the holes had to be elongated, then I'll hit it with paint. Going to paint new Stene strut fairings while the paint is mixed.
That and finally got the Airglass fork and 8.00 installed. Now 18.5" of clearance between the floor and prop tip with the factory recommended 80PSI in the strut at full extension, which comes out to 3" of exposed strut at rest. The plane is definitely more raked, but that may be a good thing for takeoff roll.
CParker offline
Do you have the cowl flap extenders on there ?
low rider offline
vail
Yeah this plane spent some time in PNG as a missionary bird so it’s got extended cowl flaps, flap switch relocate, flap dump switch, and a couple of other nifty STCs.
CParker offline
CParker wrote:Yeah this plane spent some time in PNG as a missionary bird so it’s got extended cowl flaps, flap switch relocate, flap dump switch, and a couple of other nifty STCs.
On the 185 at least, with the factory cargo pod, the cowl flap extensions were part of the kit, and required.
I'd love to see the flap dump switch setup.
It's a push button on the left grip of the yoke, gotta zoom in a little bit it's the only pic I have with it in view.
CParker offline
you can wire a trim controller on the RH ride of the yoke to be your flaps. not sure the legality. but ive seen it before
Cameron96 offline
Aircraft: C206 Turbine
That is such a great idea for the oil cooler. How are you getting that approved? I’m excited to hear how it works out.
Your center console looks nice also!
AZ Flyer offline
Aircraft: Cessna 206
