Skywagon Cowl Louver STC
There are STC out there that the issuer just gives away, Door Stewards and the Great Lakes Aero one piece windscreen are a couple examples. One simply receives a photocopy of the STC and no permission letter for those 2.
Halestorm offline
956
- Aircraft: C-182E Pponk
Sun Jul 05, 2020 11:44 am
Halestorm wrote:There are STC out there that the issuer just gives away, Door Stewards and the Great Lakes Aero one piece windscreen are a couple examples. One simply receives a photocopy of the STC and no permission letter for those 2.
Digging through my logs, it appears Alaska Bushwheels does the same thing. My tailwheel STC is just a piece of paper with a handwritten note from the installing mechanic. It was good enough for Transport Canada and also for some DAR as it made its way south.
StuBob offline
293
- Aircraft: Cessna 185 Skywagon
Soooooooo.......if someone could PM me with a source for a scan of this STC, my friend says she would be most grateful. Or send it to her at Susan dot Williams dot cpa89 at gmail dot com.
StuBob offline
293
hotrod180 wrote:Ryan, paperwork aside, I'm curious if your 185 is in flying condition?
That’s a negative ghost-rider. Too much stuff that I still don't want to talk about. I'll make a thread about it when I'm closer.
Still plugging along during the off time. This rona thing made it easier to get out to the airport more often which has helped a-lot.
pilotryan offline
343
- Aircraft: C185 / C310R
Falcon 900B
