Backcountry Pilot • Skywagon Water Transitions?
22 posts • Page 2 of 2 • 1, 2
Like Matt said practice, practice. And remember practice doesn't make perfect neccessarily. Perfect practice does make perfect performance though.
I am lucky in that I've got a setup with two taxiways about 500' apart. I make it usual practice to land and depart between them in the dirt whenever possible. Not usually at gross (3700' field elevation) but full fuel and two guys and a bit of gear. It's uphill east and downhill west. I am fairly proficient at it. When I'm heavier I usually start with 10' of flap and stroke in full when I get to the other taxiway. I like that method when you want to break ground but can accelerate in ground effect. It isn't so critical that I'd wreck the airplane if I over ran it but it would get pretty bouncy. This allows me to know fairly precisely what my capabilities are with my airplane and because I do it all the time I feel comfortable with it.
The best thing you can do when practicing is to be really specific about where you want to land do it until you get the sight picture and then do it five more times in rapid succession.
I like the MAF rule of 700' at gross. I don't think I could do that at 3700' but I bet I could do 900' or so.
lowflyinG3 offline
[/quote]
Hi Wayne,
1) Please don't take this the wrong way.
2) I'm guessing I must be reading this or interpreting this wrong.
3) If on ANY day you have missed your touch down mark by 500'-600',
water assisted landings are probably not for you 8)
4) you do bring up a good point though, It doesn't matter how short you can get stopped, if you can't pick where that short landing is going to start at :shock:
Take care, Rob[/quote]
Nah, I don't take it the wrong way. I do need to further explain. The strip that is marked has a big bush at the end and that is where the zero is. So you can't touch down at zero unless you are on a vertical glide path which is considered bad form in a 180. Also, the runway is long and I get lazy sometimes. :roll: The statement was that most airplanes can land shorter than they takeoff and my whole point is as you mentioned, you have to see how much runway is behind you when you get stopped, not how long the tracks are.
Wayne
c180pilot offline
