Skywagon Wheel Parts
Went to the hangar today and discovered a flat tire. The mechanic says there's a crack in the wheel and a missing dog, meaning it needs to be replaced. Cessna wheels are what you'd predict: rare and expensive. People who shy away from Bonanzas because of "the high price of Beech parts" are uninformed.
What alternatives to I have? I mean, besides driving on next week's vacation which, unfortunately, has become necessary.
StuBob offline
293
- Aircraft: Cessna 185 Skywagon
Alaska Airframes wheel and brake kits are great value
1269
I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
StuBob offline
293
StuBob wrote:I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
$3800? The wheel and brake kit is $2261 plus shipping. This is for the 6 bolt wheels. 3 bolt wheels are a bit cheaper. Or are your tires shot and needing to be replaced as well? Labor shouldn't be much. It's a very straight forward install.
A1Skinner on Fri May 14, 2021 7:41 pm, edited 1 time in total.
5186
What wheels do you have now? McCauley?
L16Driver offline
34
- Aircraft: Aeronca L16, Cessna A185F
A1Skinner wrote:StuBob wrote:I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
$3800? The wheel and brake kit is $2261 plus shipping. This is for the 6 bolt wheels. 3 bolt wheels are a bit cheaper. Or are your tires hot and needing to be replaced as well? Labor shouldn't be much. It's a very straight forward install.
Yes, and at that price point, shipping is free. Just order a new set of wheels from Airfames and get rid of that McCauly stuff.
10515
mtv wrote:A1Skinner wrote:StuBob wrote:I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
Not free everywhere. We Canadians pay shipping.
5186
A1Skinner wrote:mtv wrote:A1Skinner wrote:StuBob wrote:I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
Oops. You guys need to get your act together......
10515
mtv wrote:A1Skinner wrote:mtv wrote:A1Skinner wrote:[quote="StuBob"]I called Airframes Alaska, who said their wheels will work with Cleveland brakes but not whatever brakes are used with the McCauley wheels. That makes it a $3800 job plus labor. I hope it doesn't come to that.
MTV[/quote]Haha. Nothing we did, I'm not sure why its not free for us. Everything has to go over us to get south anyways...
5186
I got a set of McCauley wheels that I just removed from my 180 - the brakes have pitting but sounds like you just need the wheels.
corefile offline
637
- Aircraft: Cessna 180 - sold
The 3-holes are just shy of $1900 each. Is there a $600 reason to prefer the 6-hole?
corefile wrote:I got a set of McCauley wheels that I just removed from my 180 - the brakes have pitting but sounds like you just need the wheels.
PM sent!
StuBob offline
293
And a follow up question: is it possible to use Cleveland wheels with the stock McCauley brakes?
If I have to buy a whole kit, I think I’ll just go ABI, since it’s cheaper that Cleveland and I know it’ll be compatible with the Bushwheels I might get when I’m recovered from this little adventure.
StuBob offline
293
Not compatible with McCauley Brakes. Cleared direct to buy the whole kit.
Don’t miss the offer of used wheels posted above though if that’s more palatable.
Pinecone offline
996
- Aircraft: Cessna A185F
Yes I did on my 180 k use McCauley brakes on Cleveland wheels with right discs when my wheels were cracked. Then replaced with new style McCauley wheels with through bolts same McCauley brakes.i like the McCauley calipers.
Cub180 offline
92
- Aircraft: Cessna 180 skywagon, Supercub pa18
I’ve got a set of used Cleveland brakes I’d be happy to get rid of if it helps.
Already sold the wheels.
fredy offline
110
Thanks, fredy. I’ll contact you if I wind up needing them.
StuBob offline
293
