jcadwell wrote:I use 1" tubular webbing from REI, or other climbing stores. The stuff I buy has a 4000 lb minimum breaking strength. It's cheap ($0.50 per foot). I permanently terminate one end with an overhand knot on a bight with a shackle. The other end gets tied as needed, which usually involves a bowline about halfway up the webbing, so I tie to something in the ground, run back up to the bowline, and cinch back down. Not a fan of open hooks, as they can fall off when things are bouncing in the wind. Shackles are cheap enough. Be aware that tying knots in ropes and cords can significantly reduce breaking strength.
asa wrote:I've contemplated this a lot and my strategy has evolved over the years. For my maule, I use 3/8" transport chain with open hook ends. I find it's quick, affordable, definitely stronger than any plastic rope/webbing/strap, and doesn't have any give so I don't have to worry with the plane rocking about.
Zzz wrote:Why not just proper dynamic climbing rope then?
gahi wrote:Zzz wrote:Why not just proper dynamic climbing rope then?
this is what I use. along with carabiners top and bottom. It does stretch some initially and loose tension. so if you want it tight you need to re-tie it after a few minutes.
asa wrote:3/8" transport chain with open hook ends.
NineThreeKilo wrote:Zzz wrote:Why not just proper dynamic climbing rope then?
I’d have to actually tie a knot, like physical labor?
