Smart Phone Anemometer
I am going to glue magnets on my prop.... then my iPhone can be my tach !!!
I wonder if I could do airspeed with some M&M's !?!?!?!
flightlogic offline
616
Scolopax wrote:The app is not available to me in the app store. Does it use the microphone?
Yeah, the sound distortion due to wind is calibrated to wind speed. I thought it was pretty ingenious.
AKclimber offline
214
AKclimber wrote:Scolopax wrote:The app is not available to me in the app store. Does it use the microphone?
It sounds better in theory than it actually works. The plug-in anemometer veins is a much cooler concept.
I've carried a Kestrel 2000 for a few years, but mostly use it for windage adjustments to my scope.
2855
I just use the sound of the wind whistling through my ears. If I'm dumb enough to go fly when it's blowing real hard, there's no brain in the way to stop the wind, and the whistle is loud.
And, the whistle helps block the noise of the people telling me not to do it.
4557
- Aircraft: Old Clunker
GumpAir wrote:I just use the sound of the wind whistling through my ears. If I'm dumb enough to go fly when it's blowing real hard, there's no brain in the way to stop the wind, and the whistle is loud.
Agreed Gump. I have never been in a situation where wind estimates were not sufficient for planning my takeoff. It is fun to have numbers if it just means a simple addition to what I'm already carrying though.
Does anyone have a rule about wind speed vs slope for takeoff? for instance: " if there is a 3% grade, it will take a 15 knot wind to convince me to take off up hill?" I have taken off down hills with 8-10 knot tailwinds on several occasions. That is frequently the scenario at McKenzie Bridge.
Scolopax offline
1696
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 4aYqSexnZC
Cougar Resevoir, downstream, near McKenzie Bridge (00S), has typically a one way departure path over the dam. Mornings, the cold air is sinking down the canyons and in the afternoons the vast Oregon East Desert is sucking cold marine air inland. At least this is what I saw the few times with the seaplane.
Same scenario, for me, at McKenzie Bridge with bush wheels.
4623
- Aircraft: 2018 R44
8GCBC wrote:Cougar Resevoir, downstream, near McKenzie Bridge (00S), has typically a one way departure path over the dam. Mornings, the cold air is sinking down the canyons and in the afternoons the vast Oregon East Desert is sucking cold marine air inland. At least this is what I saw the few times with the seaplane.
I remember Cougar Reservoir back in early 70's with hot springs -lets get naked ! . In Oregon where logging trucks rule the highways I had little Dautsun Pick up with several young ladies in the back "flashing " the truck drivers that followed behind . Had a great time swimming and doing the horizontal bop. East of Eugene about 30-40 miles .
182 STOL driver offline
1529
Cool dude!
I really like your air park!
http://www.airnav.com/airport/AZ50
4623
Fri Mar 22, 2013 10:20 pm
would it have been different without bushwheels?
soaringhiggy offline
711
48 Stinson 108-3
Fri Mar 22, 2013 10:23 pm
You referring to stock 8.56 compared to 31136.R ? Yes.
Or 5.06 s on the amphib? Heck yes!
4623
