I believe the closest thing you’ll find to that in terms of diameter are the Goodyear blimp tires.lefoy84 wrote:Does anyone make an 8.50-6 6 ply for a 180. I only find the 8.50-6 4 ply from Desser.
hamer wrote:The TSO for the desser 850's states a 1600lbs rating, per tire, so as long as your bird is under 3200lbs you should be good.
whee wrote:Those smooth dessers have always raised questions among the heavier airplane guys since they are so light. I asked about them for my BH. Rob had them on his C180 and thought they were good until they weren’t. He got a flat from thorns on a dirt strip that he didn’t think would have happened with regular 850s. He removed the smoothies.
AEROPOD wrote:hamer wrote:The TSO for the desser 850's states a 1600lbs rating, per tire, so as long as your bird is under 3200lbs you should be good.
I'm curious if the 3200# weight limit is tied to any reg. By that I mean, even a 185 at 3350 will have less than 3200 on the mains, so why can't I use them on a 185. Is there a reg or AC that relates tire rating to aircraft weight, or did we just decide this on our own via internet expertise?
mtv wrote:AEROPOD wrote:hamer wrote:The TSO for the desser 850's states a 1600lbs rating, per tire, so as long as your bird is under 3200lbs you should be good.
If a TSO states maximum weight, I don't think you have to go any further. TSO stands for Technical Standard Order.....the standard there being weight rating.
I just have never seen any benefit to these tires, and am baffled by the amount of interest in them. Yes, smooth tires have the advantage of not throwing AS MUCH junk at your tail, but they'll still chuck some stuff at the tail.
And, as lightweight as these things are, they simply can't be very durable. Compare one of these to a Goodyear 8.50 sometime......Yes, the Goodyear weighs more, but it's also much more durable.
Flat tires in the boonies are no fun, for sure. Best thing you can do to avoid those is regularly check pressures. Some of the flats I've seen are from a spun tire, resulting from low pressure. Lots of pilots like to run pretty low pressure on tube type tires these days, which is fine, within reason. But, if you start at relatively low pressure, it doesn't take much leakage to get your tire down to dangerously low pressure.
But, there's no way I'd run these tires on....well, any airplane, frankly. Put some rubber protective shield on the leading edge of your stabilizer, and run decent tires.
