Help me out here and figure out what is going on... aerodynamically.
I've been experimenting with landings in my Skywagon. In most other airplanes I prefer a power off approach all the way to touchdown. I find it doesn't work really well with the Skywagon (unless you are fast, which poses its own problems)... so I use trailing throttle. Just enough to provide wash over the horizontal and give me authority.
I've been playing with the power off approach lately at 50-60mph... trying to see what works for me in the Skywagon to perfect that short landing and I find that everything is fine until I hit ground effect. Once that happens the nose drops like I've pushed it over... and I haven't changed any flight control. If I have trailing throttle this doesn't happen. My speculation is that the tail stalls when I hit ground effect. The subsequent 3-5 foot drop onto grass is no big deal, but onto pavement puts a lot of energy into the spring gear.
Full disclosure. I've got the Sportsman cuff. This happens light or heavy. It does not happen if my speed is greater than 70-75 mph. I've done stall tests and with flaps 40 and it will stall about 34 mph at altitude. That is the wing stalling.
I haven't tested techniques for actual distance, but my speculation is that with trailing throttle the distance would be greater. But if done on pavement the power-off technique does end up costing distance as you bounce quite a bit;) Common sense says just use the trailing throttle.... But I'd like to understand what is going on.
Again, my speculation is that the horizontal is stalling when I hit ground effect at 50-60 mph. What I think is happening is that ground effect interferes with the airflow over the 'top' of the horizontal (the physical bottom of the horizontal). Then the airfoil stalls. Without the lift of the horizontal to hold the nose up this results in pitching the aircraft nose down. Any thoughts?
gunny
