Backcountry Pilot • Sportsman with an AP
6 posts • Page 1 of 1
Anybody know about installing an AP on a 58 182 with a Sportsman STOL. What AP and any special issues.
Thanks
Jack
flyingjack offline
Aircraft: Husky/T206H
Re: Sportsman with an AP
I don’t think there would be an issue installing any approved autopilot in a 182 with a sportsman. Unless there’s a note in the approval forbidding it?
There has been a problem installing autopilots on Robertson airplanes as the aileron linkage is modified with the Robertson installation.
Halestorm offline
Aircraft: C-182E Pponk
STC SA4303WE is the Sportsman Approval for the 182.
The approval reads as follows:
The approval of this change in type design applies to the basic aircraft of the specified model that is otherwise unmodified. This approval should not be extended to other aircraft of this model on which other previously approved modifications are incorporated unless it is determined by the installer that the interrelationship between this change and any of those other previously approved modifications will introduce no adverse effect upon the airworthiness of that aircraft.
I read this as meaning that the installer has discretion to determine if it introduces adverse effects, and if not, can install it.
You would also need to check your intended autopilot and make sure it does not have a prohibition of some kind, as well as VGs if you intend to install them.
jcadwell offline
There are plenty of 180's with sportsman and auto pilot.
Mine is one, no issues with GFC500, works great.
StillLearning offline
I have an STEC 30 install my ‘56 and no issues on install and works great…as I recall the documents call out the Robinson mod as being problematic….butbim going on memory…..
Airdave100 offline
Aircraft: 1956 Cessna 182....N5632B
Thanks guys, I'll pass on info to my buddy.
flyingjack offline
