When taking the ppl I was never trained on this.
Seemsto me a rather important skill to have.
i have tried to practice it but dont hit the exact spot I want.
Any tips, advice you guys want to share?
motoadve wrote:When taking the ppl I was never trained on this.
motoadve wrote:I can do decent short field landings, and one after the other about same lenght 600ft.
But Im talking about precise spot landing put the tires exactly in the spot I want , not 20 ft before or after
Jaerl wrote:In that last link Trimtab posted it suggests flying a pattern at Johnson Creek. Do you guys do that? Seems like another thread was talking about how to approach Johnson Creek and I assumed it was a straight in approach.
mtv wrote:I STRONGLY suggest you find a COMPETENT flight instructor, and learn the technique in the airplane NOT on the internet.
motoadve wrote:20 ft off my landing spot seems to be ok for instructors, 600ft short field landings also ok for them, i want to be able to land right on the spot and do 400ft short field landings
Maybe more practice and practice but Im always open to hear tips frommore experienced pilots will post a video of me landing about 20 ft past the intended landing spot.
kevbert wrote:motoadve wrote:I can do decent short field landings, and one after the other about same lenght 600ft.
Good grief, hitting within +/- 20 feet is an excellent spot landing in my book. There's too many variables to literally land on a dime every time, because at slow speeds the slightest puff of wind can change your vector in any number of directions.
That said, there is one trick involving manual flaps that you can use to dramatically increase your accuracy. It's a good technique for winning spot landing contests and pissing off other contestants with electric flaps, but not a technique for general use. Learn to give it some power as you flare, just enough so that you can float along just one foot above the ground. When you get to the point you want touch down, dump the flaps. Your plane will plop down firmly. With just a little practice, you can usually get your touchdowns to +/- 1 ft.
