A little too much flying of his Cub (or whatever) on his days off,
and subconsciously was trying to land the jet the same way?
Oopsie!
Mr. Ed wrote:Reminds me of a flight I had a number of years ago. I was flying a 747-400 and after passing 10K on departure the purser called and informed me that a passenger was very upset and was going to report us to the FAA for stalling the aircraft on initial climb out. After we leveled in cruise (pre 911) I went back to talk with this fellow. He was a pilot and he knew what a stall felt like and he was absolutely certain we had stalled. I tried to be polite. Listened to his story and then asked when and where he got his type rating in the 747. He said he didn't have a type rating but was certain we had stalled. I explained that during flap retraction from flaps 5 to flaps 1 that there is an aerodynamic shudder which is what he felt, not a stall. It happens every time and is unique to the 747. He knew he was right and was reporting me. I held out my company ID, told him he was free to write down the information and report whatever he wanted. Everything is on the flight recorder. Needless to say, I never got a call from the Feds.
Reminds of a story I read recently, related by a airline pilot, of a passenger who, while loading, stopped at the cockpit door and leaned in to present his private pilot certificate. "If anyone has any trouble or gets sick up here, I'm in 12A."
Mr. Ed wrote:...From the rear of the ship, no instrumentation available, it is very difficult to know what is going on up front. Even if you are a pilot. Sometimes that even makes it worse. You don't have the instruments you normally have that confirm or refute what you are sensing so you fill in the blanks with assumptions. Five knots slow is the tolerance limit where I work. Get any slower than that and it's a mandatory go around. Looking out a rear window at relative motion across the ground is a tough way to judge airspeed. I wasn't there, didn't see and feel what you did but my guess would be that it was just a crappy landing...
Zzz wrote: That is hilarious. Reminds of a story I read recently, related by a airline pilot, of a passenger who, while loading, stopped at the cockpit door and leaned in to present his private pilot certificate. "If anyone has any trouble or gets sick up here, I'm in 12A."
Barnstormer wrote:I've got well over a thousand takeoff and landings in Stearmans in which the pilot sits at the back of the wing and has zero forward visibility. Keeping the aircraft straight and the wings level is done almost entirely with periphery vision, with a little slightly forward of 90 degrees, and seat-of-the-pants.
Grassstrippilot wrote:Throw in fly-by-wire with artificial feedback and it becomes even trickier. But I sure do love the side stick and how the bus flies. But if you ride it in the flare 4 feet above the ground in ground effect without proper correction , it will find terra firma with a thud!
Cannon wrote:Grassstrippilot wrote:Throw in fly-by-wire with artificial feedback and it becomes even trickier. But I sure do love the side stick and how the bus flies. But if you ride it in the flare 4 feet above the ground in ground effect without proper correction , it will find terra firma with a thud!
Admit it. It's all about the tray table.
