Lyc's seem to have only one impulse (RH mag?).
Most continentals seem to have impulses in both mags.
IMHO kickbacks on the bigger 6-banger Cont's are often due to
1) weak battery or starter, won't turn the engine through the compression stroke
2) letting go of the starter button too soon
3) lightweight prop not having enough mass / inertia to go through the compression stroke
My 180 has a stock 470K, C201 Mac, energizer starter, & firewall mounted odyssey. Starts just fine.
Halestorm wrote:...Situation is further exacerbated by this new generation of propellers with much less weight (inertia) in the blades. Heavier props can mask kickbacks to some extent.
Just semantics, but heavier props prevent kickbacks is how I'd put it.
