Backcountry Pilot • Starter for O200 on Champ
6 posts • Page 1 of 1
Can someone please share the process of adding a push button starter to a Champ with an O200? Curious about cost of parts, labor and time.
Icarus747 offline
Re: Starter for O200 on Champ
Are you converting from a pull starter, or does it not have a starter at all on it right now?
Amodel offline
Aircraft: Cub
A1Skinner wrote:Are you converting from a pull starter, or does it not have a starter at all on it right now?
Fresh install. No electrics or pull starter.
Icarus747 offline
Are you doing it via the 0-200 STC? Or is it all going to be field approved?
I have flown a Chief with their 12amp alternator. It’s super light and does a good job.
https://bandc.com/product/200g-alternat ... less-gear/
Hers a link to the key start kit
https://bandc.com/product/bc320-1-conti ... lation-kit
And the starter
The guys at B&C will help you out with everything, including copies of field approvals if they got them.
Give them a call.
Amodel offline
Aircraft: Cub
Keep in mind that if you install an alternator, you will be subject to requirements for ADS-B out and/or a transponder.
But you will still be exempt with a battery-only electrical system.
