Curious if a 63 175 could be converted back to a straight tail for possible tail wheel conversion in the future? Has it been done before? On a 172?
Marc
maulewaco wrote:Never seen a omni-vision 175. Thought they went for five years of fast back 58/62. I have seen the fast back swept tail done. Shortfielder on this site and barnstormers had a verticle and rudder for sale for a straight tail.
175 magnum wrote:58 &59 had the straight tail, 60 &61 had slanted tail, 62 had constant speed prop and cowl flaps, fastback and slanted tail , 63 had constant speed and cowl flaps, slanted tail and Omni vision.
Check with Stoots Aviation in Alaska or the 175 club.
I am converting my 60 175 to a straight tail, it is very easy actually. You need the vertical stab and rudder from a straight tail as well as the large forging at the end of the airframe. I am registered in the homebuilt so I do not have to worry about the STC.
hotrod180 wrote:In Canada, don't you also have the "owner maintenance category" option for experimentalizing certificated airplanes, and using whatever parts (home-made, certified, or ?) you want?
