Well,
At 5' 7" (5' 8 1/2" in cowboy boots) and 160 lbs. I fit into the Maule just fine. Despite the Jane-Fonda-exercise-video manuever I have to perform on entry, I have the seat moved all the way forward. Fortuitously, this is the perfect focal distance to the instrument panel and I don't require quadra-focal lenses to see the GPS. My vote for best Maule feature is the 85 gal. fuel capacity coupled with the Little John from Sporty's and a close second is the cargo door. Camping out of this airplane is a pleasure.
Now, to be honest, I have a real soft spot for the Stinson. In fact, my next airplane might be a Stinson. But here's a question: They (Stinsons) were built around the time when they were trying to eliminate stall/spin accidents by making silly planes like the Ercoupe without full control. Is it true that the Stinsons are set up to stall at a speed high enough to keep the ailerons flying all the way to the ground?? Does this compromise their short field performance? ...and then there's the age factor. Stinsons are the aeronautical equivalent of Joan Collins: they look real good, but how much performance is left in there? Even if the calculations show an infinte fatigue life at these load limits, how do you know that she hasn't gone over the line once or twice during that long history? Keep the T-34 in mind here. If I do end up with a Stinson, I'd plan on a conservative, easy-going life together.
I've popped the windows at 60-70 kts on the Maule and stuck my elbow out into the wind as I dribbled along over the countryside, drinking in the view. I'm sure it's the same in Stinsons. Some things never change.
Here's what you can unload from a Maule after a trip burning 70 of the 85 gallons of fuel:
http://www.youtube.com/watch?v=DZ1B3ELVZksYB
