Hendo wrote:I chemically stripped my entire 185 exterior. With the right know-how, proper equipment (airless sprayer) and a lot of elbow grease it wasn't horrible. When I moved on to the interior I used the chemical stripper as well. It was an a$$ pain of epic proportions to dig through the black Cessna insulation glue. Once I had it all removed I was unhappy with the light surface corrosion that remained underneath. It was very very light, but was difficult to address with scotch brite due to the complexity and angles between bulkheads etc.
With that in mind, I decided to try media blasting it. I discussed it with Granger and they recommended a light glass. We tented the fuselage and I went "wild dingo" on it for a full day. We kept the pressure light and only hit the surfaces that needed it. Once completed it looked amazing on the inside! I was very happy with the results. The drawback is that that crap gets everywhere! I don't care how well you prepare, it will penetrate everything! My fuselage was stripped to completely barebones and it still took me a full day of blowing, vacuuming and washing to make sure it was completely clean of any media. That was three years ago and my buddy is still complaining about glass bead all over his hangar! I would do it again, but I would never do it to anything other than a completely stripped fuselage!
The question I have for folks stripping the interiors of their airplanes is How do keep all that chemical and/or media out of the belly of the airplane, or how do you clean all that chemical and/or media out of the belly of the airplane when you're done stripping?
Using chemical stripper inside an airplane would be spooky to me, unless you could be assured of keeping that stuff out of the belly. Otherwise, you run the risk of stripping some of the interior in the belly, and the stripper and now unprotected metal in the belly is subject to corrosion....that is, after all, where moisture and "junk" collects.
My experience with these airplanes has been exclusively with airplanes equipped with a seaplane kit, which includes factory corrosion proofing in the interior of all skins. I'd never strip that stuff out, since it'd be hard to duplicate this corrosion proofing. But, all these planes I've seen on here don't have the seaplane kit, so factory corrosion proofing is minimal to non existent anyway.
