Has anyone ever seen anything like this? Any ideas? Thanks in advance!Josh
Has anyone ever seen anything like this? Any ideas? Thanks in advance!MountainWave wrote:Alright guys, I've got a weird one here for you. I have a 53' C-180 with a O-470-K. I have single probe EGT/CHT. If i pull my cabin heat during any phase of flight I get a 50 degree drop in CHT temperature. Also my CHT's are running high with the cabin heat closed. (ie. around 400 degrees in cruise 100 degrees LOP) When i open the cabin heat i get normal CHT's. ( ie. 350 degrees in cruise 100 degrees LOP) I checked all of the scat hoses for air leaks. Inspected the CHT wiring from plug to gauge and all of it seems to be in its place and sufficiently tightened. I'm baffled... (no pun intended)Has anyone ever seen anything like this? Any ideas? Thanks in advance!
Josh
mtv wrote:First, I would never recommend running ANY engine lean of peak without a full multi probe engine monitor. That goes double for a carbureted engine.
Second: 100 lean of peak? Really? Who suggested that was a good idea? I’m not sure you could get there, assuming your one probe and instrument are accurate.
Or are you a troll?
hotrod180 wrote:Do you still have the dual exhaust system,
or did you convert to single exhaust when you went to the K engine?
FWIW my 53 has a K, but still has the dual exhaust (converted to 4 bolt flanges).
Which cyl is your CHT probe on?
C180 TCDS #5A6 note 4 says it should be on cylinder #2 through s/n 18051445, which covers 1953 180 through 1964 180G.
That's on the LH side of the engine.
With the dual exhaust system the LH bank of cylinders ought to be supplying carb heat,
cabin heat is supplied by the RH bank.
Also, CHT's will read differently depending on whether you have a bayonet probe,
or a spark-plug-gasket type probe.
See engine TCDS #E-273, note 1.
Redline with a gasket type probe is 525,
with a bayonet type probe it's 460.,
So calculate where in the operating range your in-flight CHT is accordingly.
asa wrote:MountainWave wrote:Alright guys, I've got a weird one here for you. I have a 53' C-180 with a O-470-K. I have single probe EGT/CHT. If i pull my cabin heat during any phase of flight I get a 50 degree drop in CHT temperature. Also my CHT's are running high with the cabin heat closed. (ie. around 400 degrees in cruise 100 degrees LOP) When i open the cabin heat i get normal CHT's. ( ie. 350 degrees in cruise 100 degrees LOP) I checked all of the scat hoses for air leaks. Inspected the CHT wiring from plug to gauge and all of it seems to be in its place and sufficiently tightened. I'm baffled... (no pun intended)Has anyone ever seen anything like this? Any ideas? Thanks in advance!
Josh
What setting is the cabin air on? Have you looked at the cabin air/heat divider valve thing on the right side of your firewall? I think there is a certain setting at which the valve can allow cold high pressure air from the top of the cowling to bypass the cylinders and come around to the low pressure (bottom) side of the engine. This is hard to explain, but easy to see if you remove your cowling and look inside that valve assembly while playing with the controls to cabin air/heat.
Even with that, it seems that it would be hard to get so much airflow through there to change CHT's 50deg.
-Asa
