Backcountry Pilot • Super Cub 40K?
Super Cub 40K?
59 postsPage 3 of 31, 2, 3
Re: Super Cub 40K?
Joel Milloway is extending the wings on the S7's he builds as I understand it. Good/bad, I don't know. Would like to try one out though. Love experimental!!!!
gbflyer offline
Re: Super Cub 40K?
He has a trick Hoerner type tip, the overall span remains the same, but the true airfoil carries all the way out to the tip, so best of both worlds, more effective span while no actual greater span. I had a pair, bought after my build, and was all set to rip fabric off and install them but ended up taking my beat up stock 'glas tips off and throwing them in the dumpster, saving 7 lbs. Then I weighed Joel's carbon ones and they were a few lbs less (these weights are approximate, I can't remember exactly, but it wasn't a pound or two, but less then ten), and then I sold his tips to someone still building thus easily ably to install, and put a fresh coat of Poly-Tone over my bow tips and called it good! Saved that weight, but yeah I'd use them if building new.
Re: Super Cub 40K?
Tom wrote: I would like to see a pacer get in in less than 300 ft. Same on takeoff.
They can certainly keep up with a Cub, with mods, for less than the cost of a Cub overall.
http://www.youtube.com/user/avcan
I say "keep up with", not overtake.... but the few places a Cub can go, where a modded Pacer cannot, aren't places you regularly need to be.
Re: Super Cub 40K?
mtv wrote:
River rat wrote:If I had 40K and wanted a super cub I'd order up a backcountry supercubs or carbon cub kit. Ya I know a cc kit is more like 60 but, ( there soooo sweet!).
Now, that right there is FUNNY! :lol:
I have a couple of friends who've gone that route and the LEAST cost I've heard from them is on the order of $110 K plus one hell of a lot of labor.
Good luck finding ANY kind of SC kit you could actually fly for $40 K
I know a fellow who built one from SCRATCH, meaning from plans, for about that......a remarkable accomplishment indeed, and a HUGE amount of work, scrounging for parts, lots of tools and expertise, a place to build, etc.
You are right Mike - although I would hasten to add, you can't have any other (comparable) brand new aeroplane for anywhere near the price of a completed homebuilt kitset, from what I have seen.
Expensive? yes.
Worth it? yes.
Get what you pay for, definitely.
Re: Super Cub 40K?
courierguy wrote: This effect is why I leave the spare tire out of my 2200 lb Toyota Yaris (46 mpg) when driving up and down the mountain I live on, while I carry the spare in the 1 ton Dodge diesel (18 mpg). No free lunch for all the above examples, more potential weight carrying capacity costs, but it's worth when or if you need it. That less then 30' span has made all the difference for me a few times, hell I wish it was narrower I'd have less scrapes on the tips!
Why keep a spare on your dually? It has two already. And ten-plies. :wink:
mepps1 offline
Re: Super Cub 40K?
A little thread drifting but, my idea of a "workhorse" is the Cessna and/or de Havillands.
Saltwater float flying is the hardest operation generally on an aircraft. The Cessna/Beaver line can out last most on floats. A 206 and Beaver, here in Hawaii, proves this pretty well.
But, I also saw a Beech 18 in Micronesia which had 25,000+ hours. It was flying off coral atolls for years and was stellar!
OK, back to 40K cubs ... (or let's say $150K airworthy) :D
Re: Super Cub 40K?
8GCBC wrote:....... A 206 and Beaver, here in Hawaii, proves this pretty well.
Just saw that outfit for sale on barnstormers...looks like an opportunity for somebody, maybe.
bart offline
Aircraft: Cessna 180
Re: Super Cub 40K?
"...The founder of the company, Pat Magie, has flown 39,000 accident free hours with about 32,000 hours in seaplanes--which now is probably the world's record. He was also named as the National Seaplane Pilot of the year in 2000. He flew as a bush pilot in Northern Minnesota, Canada and Alaska for many years flying fishermen, hunters, forest fire suppression and freight of all descriptions...."
He gave Wiplinger his check I was told, by Bob himself. Classic dude.
Super Cub 40K?
That's a pretty cool history!
I've always held a dream of building an experimental J-3 one of these days. Light light light light but with wing tanks so I can sit up front.
S-7 doesn't sound too shabby either.
Re: Super Cub 40K?
Had a quick browse in barnstormers and found half a dozen Stinson 108s in the 30-50k range - tough aircraft and one of my favourite sleepers in the vintage/bush tailwheel sector.
L18C-95 offline
Aircraft: Piper L18C-95
Re: Super Cub 40K?
I learned to fly in a PA-11 and owned that plane (with a C90 motor) when I first started flying S-7s. I loved my -11, but there was no comparison between the two. The power to weight ratio in the S-7 with the 100hp Rotax is one of the best I've ever flown.
It's even more fun with 140hp turbo Rotax and slats, but you ain't gonna get one of those for $40k! ;)
RanchPilot offline
Re: Super Cub 40K?
AK_Logan wrote:
PAMR MX wrote:This beast started out at 75k when i was selling my cub last winter. Aside from the engine being high time it may have some other issues...
http://anchorage.craigslist.org/for/4580040407.html
Called about that one a while ago. It failed compression on 3 of 4.
Also ground looped with a poor "repair" job. Someone beat the frame straight with a hammer and slapped a coat of paint on it.
There is a 90hp and a 105hp PA-18 up here for under $50k. Neither currently have flaps, but I'm under the impression they are on the type certificate for the 105hp...
http://kusko.net/cub/the-cub-is-for-sale/
TradeCraft offline
Re: Super Cub 40K?
And, adding those flaps are going to drain another, what?...$12 to $15 K out of your bank account.
Or, you could do a full rebuild AND add the flaps and only be down $150 K.....
Re: Super Cub 40K?
hahahahahahahaha. Yep. No way around it.
Mister701 offline
Aircraft: Rans S7LS
Re: Super Cub 40K?
kase offline
Re: Super Cub 40K?
FWIW, If the cub Kase is pointing at is the one referencing a current a recent experimental build, I can say that the owner is an experienced, knowledgeable cub guy and his 18 should be straight forward and turn key. He has built a cool one off experimental, as well as a J5 from a pile of parts. Maybe not a $100K cream puff, but I'd have no issues hoping in a cub of his and flying down to Arizona from Valdez.
Take care, Rob
Rob offline
Re: Super Cub 40K?
kase wrote:http://alaskaslist.com/1/posts/10_Transportation/59_Aircraft/
Cub for 42k
something wrong with the link.
Mister701 offline
Aircraft: Rans S7LS
Re: Super Cub 40K?
Worked for me.
Hafast offline
Re: Super Cub 40K?
TradeCraft wrote:
AK_Logan wrote:
PAMR MX wrote:........... ground looped with a poor "repair" job. Someone beat the frame straight with a hammer and slapped a coat of paint on it. ......
"Beat to fit, paint to match". My kind of guy.
