mtv wrote:You might want to add some foam pipe insulation on that forward induction crossover tube. On Cessna 180's, it's really hard to get them to run smooth in cold weather without that forward tube insulated. It's not hot there, so just put some of the split lengthwise pipe insulation on it, and tie-wrap it in place. It may not be necessary on the Stinson, but it really is on the 180 with this engine.
I'll second that, but I would suggest using the same firesleeve that you used on the crankcase vent tube, just in case. I put that on my 180 after the first couple of years and it did make a difference in winter ops. The other thing that I routinely do with the 470U is pull the throttle back about half an inch to set up a little turbulence in the induction tubing that helps get more even mixture distribution. If you have a six probe EGT/CHT, it's easy to see the EGT's change as you pull the throttle. Usually doesn't take more than 1/2 inch of manifold pressure although in some circumstances full throttle seems to have better mixture distribution. I never have figured out why. This will also let you lean more aggessively at higher altitudes. At some throttle settings and altitudes I can even run a few cylinders lean of peak smoothly. YMMV!
I also use some carb heat in cruise below about 30 OAT, but you must have a carb temp gauge to do this safely, or you might just get the carb
into the icing range from below it.
What a rocket ship! You should try talking AOPA into doing a better than new Stinson!
Rocky
