Super Stinson with Bushwheels???
Interested in 108-3 information with regard to how strong the legs are. Considering a purchase and am somewhat concerned with how the stumps will hold up to rough country landings...anyone?
tkearns offline
11
tk
No experience with bushwheels here, but if you saw some of my landings, you wouldn't worry one bit about the strength of the landing gear!
RDUStinson offline
268
108-3
How stout are they built? 31's make up for plenty...just curious as to how well they are constructed...
tkearns offline
11
tk
The Stinson airframe in general is built VERY stout. I'm not sure what non-subjective measure I could otherwise use, but the landing gear consists of heavy heat-treated tapered steel gear legs which pivot on the lower fuselage longerons, and then compress a pair of big spring-oil hydraulic shock oleos. Thes oleos are mounted to a large tubing cluster in the center lower portion of the fuse. All of this appears to be pretty sturdy. There is some maintenance required of the oleos, pivot shaft (greasing), and pivot bolts, but if covered, you should be fine.
I have pictures somewhere I could dig up for you if you'd like- I think having a look at one would make you feel pretty comfortable. I can't imagine you'd do any damage with a big set of tires, even under the most adverse conditions.
I'm sure others will weigh in...
-Bill
RDUStinson offline
268
108-3
Matt we need that picture you have.
6977
There's nothing to worry about there! That airframe and gear is way strong!
JH
hardtailjohn offline
924
Thu May 27, 2010 10:56 am
Here's a good page with some photos of the airframe and gear:
http://www.hangar9aeroworks.com/NC6197M/108project.htmlWhen I had my annual done a in March we looked into the gear because it was sagging to one side. After tearing apart the gear we found that one of the springs was sheared in half. No other parts were damaged and we replaced both springs (Univair sells them for 125.00 each if I remember correctly). I'm almost certain that it was this way when I purchased the plane and it's nice to know that the spring itself is the weak link. The frame and gear attachment is very stout.
2803
Stinson gear is very strong, it is mounted to the strongest grouping of tubes in the fuse. Not like a Cessna that can tear out a gear box. The mounts and pivot points are very strong and the shock struts will absorb lots of energy. The axles are 11/2 heavy wall, I don't think you will break this part of the plane unless you break most of the rest of it.
shorton offline
662
- Aircraft: Stinson 108-2
Mon May 31, 2010 10:15 pm
tkearns offline
11
tk
One just popped up on barnstormers, there are two pictures with 26" bushwheels if you want to see what it looks like.
porterjet offline
776
KSBP
porterjet wrote:One just popped up on barnstormers, there are two pictures with 26" bushwheels if you want to see what it looks like.
That ad says it comes with 31's..and they kind of look bigger than 26s in the pics.
http://www.barnstormers.com/classified_ ... 108-3.html
1736
Looks like a pretty sweet deal to me. I never had one, but I sure like the idea.
gb
gbflyer offline
2317
ah, you're right, don't know where I got 26 from.
porterjet offline
776
KSBP
Nice plane!!! Maybe I'll see it in my hangar soon.
2803
mountainmatt wrote:Nice plane!!! Maybe I'll see it in my hangar soon.
1736
