Backcountry Pilot • Superseding Lycoming fuel injection AD 2011-26-04 (Fire HAZ)
1 postPage 1 of 1
FAA AD database wrote:SUMMARY: We are superseding airworthiness directive (AD) 2011-26-04 for certain fuel injected reciprocating engines manufactured by Lycoming Engines. AD 2011-26-04 required inspection, replacement if necessary, and proper clamping of externally mounted fuel injector fuel lines. This new AD retains the requirements of AD 2011-26-04, and expands the list of affected engine models. This AD was prompted by revised service information that added engine models to the applicability. We are issuing this AD to prevent failure of the fuel injector fuel lines, which could lead to uncontrolled engine fire, engine damage, and damage to the airplane.
2015-19-07 - Engine/Lycoming Engines/AEIO-320-D1B
2015-19-07 - Engine/Lycoming Engines/AEIO-320-D2B
2015-19-07 - Engine/Lycoming Engines/AEIO-320-E1B
2015-19-07 - Engine/Lycoming Engines/AEIO-320-E2B
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1A
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1B
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1B6
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1D
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1E
2015-19-07 - Engine/Lycoming Engines/AEIO-360-A1E6
2015-19-07 - Engine/Lycoming Engines/AEIO-360-B1F
2015-19-07 - Engine/Lycoming Engines/AEIO-360-B1G6
2015-19-07 - Engine/Lycoming Engines/AEIO-360-B1H
2015-19-07 - Engine/Lycoming Engines/AEIO-360-B2F
2015-19-07 - Engine/Lycoming Engines/AEIO-360-B4A
2015-19-07 - Engine/Lycoming Engines/AEIO-360-H1A
2015-19-07 - Engine/Lycoming Engines/AEIO-360-H1B
2015-19-07 - Engine/Lycoming Engines/AEIO-540-D4A5
2015-19-07 - Engine/Lycoming Engines/AEIO-540-D4B5
2015-19-07 - Engine/Lycoming Engines/AEIO-540-D4D5
2015-19-07 - Engine/Lycoming Engines/AEIO-540-L1B5
2015-19-07 - Engine/Lycoming Engines/AEIO-540-L1B5D
2015-19-07 - Engine/Lycoming Engines/AEIO-540-L1D5
2015-19-07 - Engine/Lycoming Engines/AIO-320-A1B
2015-19-07 - Engine/Lycoming Engines/AIO-320-B1B
2015-19-07 - Engine/Lycoming Engines/AIO-320-C1B
2015-19-07 - Engine/Lycoming Engines/AIO-360-A1A
2015-19-07 - Engine/Lycoming Engines/AIO-360-A1B
2015-19-07 - Engine/Lycoming Engines/AIO-360-B1B
2015-19-07 - Engine/Lycoming Engines/HIO-360-A1A
2015-19-07 - Engine/Lycoming Engines/HIO-360-A1B
2015-19-07 - Engine/Lycoming Engines/HIO-360-B1A
2015-19-07 - Engine/Lycoming Engines/HIO-360-C1A
2015-19-07 - Engine/Lycoming Engines/HIO-360-C1B
2015-19-07 - Engine/Lycoming Engines/HIO-360-D1A
2015-19-07 - Engine/Lycoming Engines/HIO-360-E1AD
2015-19-07 - Engine/Lycoming Engines/HIO-360-E1BD
2015-19-07 - Engine/Lycoming Engines/HIO-360-F1AD
2015-19-07 - Engine/Lycoming Engines/HIO-360-G1A
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IGO-480-...
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IGO-540-...
2015-19-07 - Engine/Lycoming Engines/IO-320-B1A
2015-19-07 - Engine/Lycoming Engines/IO-320-B1C
2015-19-07 - Engine/Lycoming Engines/IO-320-C1A
2015-19-07 - Engine/Lycoming Engines/IO-320-D1A
2015-19-07 - Engine/Lycoming Engines/IO-320-D1B
2015-19-07 - Engine/Lycoming Engines/IO-320-E1A
2015-19-07 - Engine/Lycoming Engines/IO-320-E1B
2015-19-07 - Engine/Lycoming Engines/IO-320-E2A
2015-19-07 - Engine/Lycoming Engines/IO-320-E2B
2015-19-07 - Engine/Lycoming Engines/IO-360-A1A
2015-19-07 - Engine/Lycoming Engines/IO-360-A1B
2015-19-07 - Engine/Lycoming Engines/IO-360-A1B6
2015-19-07 - Engine/Lycoming Engines/IO-360-A1B6D
2015-19-07 - Engine/Lycoming Engines/IO-360-A1C
2015-19-07 - Engine/Lycoming Engines/IO-360-A1D
2015-19-07 - Engine/Lycoming Engines/IO-360-A1D6
2015-19-07 - Engine/Lycoming Engines/IO-360-A2A
2015-19-07 - Engine/Lycoming Engines/IO-360-A2B
2015-19-07 - Engine/Lycoming Engines/IO-360-A3B6
2015-19-07 - Engine/Lycoming Engines/IO-360-A3B6D
2015-19-07 - Engine/Lycoming Engines/IO-360-B1B
2015-19-07 - Engine/Lycoming Engines/IO-360-B1D
2015-19-07 - Engine/Lycoming Engines/IO-360-B1E
2015-19-07 - Engine/Lycoming Engines/IO-360-B1F
2015-19-07 - Engine/Lycoming Engines/IO-360-B1G6
2015-19-07 - Engine/Lycoming Engines/IO-360-B2F
2015-19-07 - Engine/Lycoming Engines/IO-360-B2F6
2015-19-07 - Engine/Lycoming Engines/IO-360-B4A
2015-19-07 - Engine/Lycoming Engines/IO-360-C1A
2015-19-07 - Engine/Lycoming Engines/IO-360-C1B
2015-19-07 - Engine/Lycoming Engines/IO-360-C1C
2015-19-07 - Engine/Lycoming Engines/IO-360-C1C6
2015-19-07 - Engine/Lycoming Engines/IO-360-C1D6
2015-19-07 - Engine/Lycoming Engines/IO-360-C1E6
2015-19-07 - Engine/Lycoming Engines/IO-360-C1F
2015-19-07 - Engine/Lycoming Engines/IO-360-C1G6
2015-19-07 - Engine/Lycoming Engines/IO-360-F1A
2015-19-07 - Engine/Lycoming Engines/IO-360-J1A6D
2015-19-07 - Engine/Lycoming Engines/IO-360-L2A
2015-19-07 - Engine/Lycoming Engines/IO-360-M1A
2015-19-07 - Engine/Lycoming Engines/IO-360-M1B
2015-19-07 - Engine/Lycoming Engines/IO-540-A1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-AA1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-AA1B5
2015-19-07 - Engine/Lycoming Engines/IO-540-AB1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-AC1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-AE1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-B1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-B1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-C1B5
2015-19-07 - Engine/Lycoming Engines/IO-540-C1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-C4B5
2015-19-07 - Engine/Lycoming Engines/IO-540-C4D5D
2015-19-07 - Engine/Lycoming Engines/IO-540-D4A5
2015-19-07 - Engine/Lycoming Engines/IO-540-D4B5
2015-19-07 - Engine/Lycoming Engines/IO-540-E1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-E1B5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1B5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1D5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1E5
2015-19-07 - Engine/Lycoming Engines/IO-540-G1F5
2015-19-07 - Engine/Lycoming Engines/IO-540-J4A5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1A5D
2015-19-07 - Engine/Lycoming Engines/IO-540-K1B5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1D5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1E5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1E5D
2015-19-07 - Engine/Lycoming Engines/IO-540-K1F5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1F5D
2015-19-07 - Engine/Lycoming Engines/IO-540-K1G5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1G5D
2015-19-07 - Engine/Lycoming Engines/IO-540-K1H5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1J5
2015-19-07 - Engine/Lycoming Engines/IO-540-K1J5D
2015-19-07 - Engine/Lycoming Engines/IO-540-K1K5
2015-19-07 - Engine/Lycoming Engines/IO-540-L1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-M1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-M1B5D
2015-19-07 - Engine/Lycoming Engines/IO-540-M1C5
2015-19-07 - Engine/Lycoming Engines/IO-540-N1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-P1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-R1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-S1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-T4A5D
2015-19-07 - Engine/Lycoming Engines/IO-540-T4B5
2015-19-07 - Engine/Lycoming Engines/IO-540-T4B5D
2015-19-07 - Engine/Lycoming Engines/IO-540-T4C5D
2015-19-07 - Engine/Lycoming Engines/IO-540-V4A5
2015-19-07 - Engine/Lycoming Engines/IO-540-V4A5D
2015-19-07 - Engine/Lycoming Engines/IO-540-W1A5
2015-19-07 - Engine/Lycoming Engines/IO-540-W1A5D
2015-19-07 - Engine/Lycoming Engines/IO-540-W3A5D
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IVO-360-...
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IVO-540-...
2015-19-07 - Engine/Lycoming Engines/LIO-320-B1A
2015-19-07 - Engine/Lycoming Engines/LIO-320-C1A
2015-19-07 - Engine/Lycoming Engines/LIO-360-C1E6
2015-19-07 - Engine/Lycoming Engines/LTIO-540-F2BD
2015-19-07 - Engine/Lycoming Engines/LTIO-540-J2B
2015-19-07 - Engine/Lycoming Engines/LTIO-540-J2BD
2015-19-07 - Engine/Lycoming Engines/LTIO-540-N2BD
2015-19-07 - Engine/Lycoming Engines/LTIO-540-R2AD
2015-19-07 - Engine/Lycoming Engines/LTIO-540-U2A
2015-19-07 - Engine/Lycoming Engines/LTIO-540-V2AD
2015-19-07 - Engine/Lycoming Engines/LTIO-540-W2A
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/TIO-360-...
2015-19-07 - Engine/Lycoming Engines/TIO-540-A1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-A1B
2015-19-07 - Engine/Lycoming Engines/TIO-540-A2A
2015-19-07 - Engine/Lycoming Engines/TIO-540-A2B
2015-19-07 - Engine/Lycoming Engines/TIO-540-A2C
2015-19-07 - Engine/Lycoming Engines/TIO-540-AA1AD
2015-19-07 - Engine/Lycoming Engines/TIO-540-AB1AD
2015-19-07 - Engine/Lycoming Engines/TIO-540-AB1BD
2015-19-07 - Engine/Lycoming Engines/TIO-540-AE2A
2015-19-07 - Engine/Lycoming Engines/TIO-540-AF1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-AF1B
2015-19-07 - Engine/Lycoming Engines/TIO-540-AG1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-AH1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-AJ1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-AK1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-C1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-E1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-F2BD
2015-19-07 - Engine/Lycoming Engines/TIO-540-G1A
2015-19-07 - Engine/Lycoming Engines/TIO-540-J2B
2015-19-07 - Engine/Lycoming Engines/TIO-540-J2BD
2015-19-07 - Engine/Lycoming Engines/TIO-540-N2BD
2015-19-07 - Engine/Lycoming Engines/TIO-540-R2AD
2015-19-07 - Engine/Lycoming Engines/TIO-540-S1AD
2015-19-07 - Engine/Lycoming Engines/TIO-540-U2A
2015-19-07 - Engine/Lycoming Engines/TIO-540-V2AD
2015-19-07 - Engine/Lycoming Engines/TIO-540-W2A
2015-19-07 - Engine/Lycoming Engines/TIVO-540-A2A
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IO-720-A...
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IO-720-B...
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IO-720-C...
2015-19-07 - Engine/Textron Lycoming, AVCO Corporation/IO-720-D...
1 postPage 1 of 1
