Surefly backup battery location
This subforum is meant to organize topics for tricycle utility aircraft 205, 206, 207, maybe 208 if you're really cool.
Good morning. Just wondering if anyone is running the TCW backup battery with the dual surefly setup? Wondering where you mounted the TCW battery. I'm putting one in a C205 and was thinking of mounting it in the tunnel above the nosewheel in the avionics bay that's there. But they say in the install manual to not mount it firewall fwd. Id rather not mount it way in the tail, running wires all the way back and fwd again just doesn't make a ton of sense to me. Anyone lese have it mounted up there on their 205/206?
Thanks
5218
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
I have not, but am interested in how much battery do you need?
Glidergeek offline
1944
- Aircraft: 1968 P206C
DG 400
Glidergeek wrote:I have not, but am interested in how much battery do you need?
You need a minimum 3aH battery for the second esim in case of an electrical failure so you can fly somewhere to land.
5218
