According to legend, Sweetwater is the strip that was originally built or used to test the reverse-mounted JATO on the front of a C-130 that was going to go into Iran to rescue the hostages about 30 or 32 years ago. The aircraft crashed and was destroyed, and they went with helicopters instead, with disastrous results. I think you can find the video of the Herc accident online.
The Marine Corps has used it for training, and the glider pilots out of Minden NV have used it as an emergency strip many times. That I believe is your key... contact the glider operations at Minden NV (High Country Soaring, if they a re still operating with that name) and ask them what the current condition of the Sweetwater strip is. Also, contact RESCO (Region 12 Soaring Club), and ask who might know the status of Sweetwater airport. Contact the Soaring Society of America
http://www.ssa.org. Ask SSA for the contact info for Region 11 (I think that's the area for Minden). Their members will be the ones who need to have current info on that strip.
Another avenue for information is to contact Rosaschi Dusters, which is at Rosaschi Ranch, a small airport 20 or 30 miles north of Sweetwater. Their local pilots will probably know something. Smith Valley airport is near there as well.
In the distant past when I flew sailplane competitions in that area, Sweetwater was a well maintained, wide, C-47 sized airstrip. All else fails, drag it a few times at 20 feet altitude looking for ruts and craters, then land and enjoy. The large "bowl" shaped cutout in the mountain just south and east of the airstrip is known far and wide for the tremendous updrafts it generate in the spring, summer and fall. If you fly in to that area during the warm part of the day, be advised. I've personally had sustained rates of climb in that "house thermal" exceeding 1800 FPM in a heavy racing glider with a wing loading in excess of 10 lb/ sq ft .
Now as for the time I landed a glider on the helicopter pad at the Mtn. Warfare Training Center without permission... that's another story
