Jaerl wrote:Looks like the main gear on the older Cessnas are about the same thickness on both the Taildraggers and Tricycles. When your landing a nosewheel plane you can hold the front wheel off till you are at a pretty slow speed. I really don't see a problem here but what do I know? Are tailwheels really that much better? How about some stories about nosegear being torn from the planes and such
from you more experienced guys.
Speaking of which. This just happened this month. From N.T.S.B. (ntsb.gov).
NTSB Identification: WPR09LA445
14 CFR Part 91: General Aviation
Accident occurred Friday, September 11, 2009 in Chemehuevi Valley, CA
Aircraft: CESSNA 182K, registration: N2819R
Injuries: 3 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On September 11, 2009, about 1220 Pacific daylight time, a Cessna 182K, N2819R, landed hard and porpoised down the runway before coming to rest inverted at the Havasu Palms dirt airstrip, Chemehuevi, California. The pilot/owner operated the airplane under the provisions of 14 Code of Federal Regulations Part 91, as a personal flight. The pilot and two passengers were not injured. The airplane sustained structural damage to the tail section. Visual meteorological conditions prevailed for the flight that departed an unknown location, with a planned destination of Havasu Palms. No flight plan had been filed.
According to the pilot, he made the approach to landing over the river. The airspeed was 60 knots, and as he reduced the power to flare, the airplane was "caught in a downdraft." The airplane landed hard, bounced back up into the air in an "erratically unusual attitude," bounced a second time, and as the airplane came back down a third time, the nose landing gear sheared off. The pilot reported that the airplane slid off the runway and flipped over.
The pilot reported that the winds were moderate, with the windsock pointing down the runway. The pilot stated that he landed with a slight tailwind.
