Hi all,
I was wondering what is the max crosswind that you taildragger pilots feel comfortable with?
In my Musketeer I can deal with a 20 knot crosswind and a 25 knot crosswind if I work at it.
-Todd Giencke
Dusty wrote:During my sign off my instructor and i were doing t&l's in 35 knot winds gusts to 45. I wasn't so sure but he didn't seem to mind. Something about being the only plane in the air is a little unerving. The rollout is the tricky part.
mtv wrote:Gump,
Yep, that works, right up till you hit that little patch of dry pavement, where there's a bare spot-no ice.
Pavement sucks. I think paved runways should be outlawed, except at CLass B primary airports.
You guys can be brave all you want, but there's almost always an alternative somewhere close.
mtv wrote:Too many variables to give a hard number.
mtv wrote:I landed at Fleming Field the other day in a gusty, nasty crosswind, on pavement and it was one of the uglier landings I've made in a while. Mind you, I never felt like I was losing control, but it just sucks to blush when you taxi past the kid on the mower alongside the taxiway who has a shit-eating grin on his clock....
mtv wrote:Pavement sucks. I think paved runways should be outlawed, except at CLass B primary airports.
With a tailwheel say a Maule M-5-180
Student Pilot wrote:In most heavier stuff, direct 25/30 cross is nearly enough. 180's and 185's are pretty good, bigger stuff like Beavers with slab sides are OK up to about that. If it's any more than that you can usually land across the strip or on a taxiway that's more into wind. I'd prefere tailwheels in very strong winds, it's a matter of personal preference.
Today I was working with up to 25 knot direct crosswinds with a nose wheel with no real problems, had to stir it a bit with the ailerons to use the aileron drag to pull the wing into wind. Did 70 landings and knocked off at 2.30pm.
N6EA wrote:Is this on Microsoft Flight Sim or ???
Mark
ravi wrote:If you want to know what the x-wind component is for a tail dragger, read the POH. I'm dubious of anyone's claim that they are landing in an actual 20 knot direct x-wind.
