Tailwheel chain - why?
So my buddy asked me a question I can't answer - I hope someone here can!
His question was:
Why use chain for tailwheel steering, why not a cable or something? The chain always ends up rusted and worn through, and looks 'agricultural'.
The best I could do was "it's easy to replace, and cheap".
Battson offline
1810
- Aircraft: Bearhawk 4-place
IO-540 260hp
Very easy to adjust the length by removing or adding links.
maules.com offline
561
I expect the answer lies in the fact that most tailwheels steered by chains come from circa '30's / 40's airplanes.. cheap and easy...
C180/185 series are in fact steered by cables, as are most larger airplanes.
Having said all that, it is my opinion that a cub sized airplane used in the sticks does nicest with the ears cut off the steering head and the tailwheel run free castering...
take care, Rob
Rob offline
1569
