Once&future, the technique should work equally for trigears as for taildraggers.
First trick is to judge getting your tail as close to the fence as possible as you come around followed by full power at a point about 20deg from takeoff direction (varies with aircraft and thrust).
The idea is you already have overcome tyre/wheel rolling resistance plus start and acceleration of the 'mass' and the bonus is that the prop is being moved into undisturbed/clean air, rather than turbulant/dirty air as in holding brakes and releasing, plus as noted, no rock damage.
