Along with the Tanis, I have a small ceramic heater in the luggage area to keep the interior above freezing. This really helps the instruments and, since the battery is under the front passenger seat, it is much easier on it to.
This approach seems to be working great because each time I get in the airplane, I can hear little voices from the engine, instruments and battery thanking me!
Anyway, a fellow mentioned to me that leaving the Tanis heater on for extended periods was probably not a good practice because the changes in temperature would cause a moisture build up in the engine. I should only turn it on before using the plane. The Tanis instructions and web site do not say anything either way. It seems like keeping the engine warm would keep the moisture out of the engine.
So having nothing to do at the moment I thought I would ask you guys about this. Thoughts?
