KPDX 051553Z 00000KT 1/8SM R10R/0600V0700FT FZFG VV002 M02/M03 A3044 RMK AO2 TWR VIS 1/4 SLP307 I1001 T10221028
I can't even see the de-icer truck 50 feet from the terminal window, and you guys are landing!
I'm glad you do what you do.
Zzz wrote:...for getting me in and out of here this morning:
Grassstrippilot wrote:Often when asked what the wx is, in my head I'm thinking..."Does it matter? We are going anyway." The point being, these machines are pretty impressive with what they can do and there isn't a lot that is a show stopper. It's pretty amazing to watch the automation do a real Cat III approach. This type of flying has its moments.
Zzz wrote:Grassstrippilot wrote:Often when asked what the wx is, in my head I'm thinking..."Does it matter? We are going anyway." The point being, these machines are pretty impressive with what they can do and there isn't a lot that is a show stopper. It's pretty amazing to watch the automation do a real Cat III approach. This type of flying has its moments.
I talked to a pilot in the terminal and asked him what the story was with cat III at PDX. There is a Cat III on 10R which is all dandy but the limiting factor is the aircraft. The Horizon guys were equipped with HUD on their Q400s but the Skywest CRJs were not, supposedly. The Horizon guys were getting in while that METAR above was active.
Mr. Ed wrote:We require 500 RVR for takeoff. At typical Vr speed for my aircraft that's only about a 2 second look ahead distance, not much. Landing requires a reported RVR of 300 to start the approach but once established on the final segment it can go down to zero and we can continue to land. Trying to find your way to the gate can be a bit sporty. If it isn't at least 65' in front of me I can't see it due to the cut off angle of the nose. Anything less than 200' & 1/2 mile vis company requires an autoland. 3 autopilots all coupled up, does a nice job but it's very creepy feeling the wheels roll on when you can't see the ground. Fortunately, that happens in the simulator much more frequently than in real life.
