Well. Some of you might have seen that I was looking at a Starduster in Vancouver Washington. I sent a hard core Starduster guy (Dave Baxter) over there with his favorite mechanic (Dave Aldred) for some inspection, assessment, and collective thinking.
The airplane is a 9 outside and an 7 or so inside. Old instruments. Some control linkage looseness. Most hoses are vintage 1973. A VAL radio, no transponder. Well designed inverted systems.
It's an O-320A2(?) Lycoming with 1835 hours Since new and 635+/- on top. It had a prop strike inspection in 2002 with no mention of a magna-flux of the crank, but the crank gear was changed out at that time and the engine was put back into service. It's had virtually no use since that time and very little use for the preceding several/many years. This is not good for a Lycoming camshaft and it's assorted parts. It's got Bendix mags and it's got a pressure carb that has the original 1973 black diaphragm on it. Not good. The carb rebuild will be about $2500 and the Bendix mags can either go to Slick for a crush and exchange or they can be inspected and repaired as necessary. I would probably just do the IRAN. Bendix is a better mag no matter what transpired with all those ADs.
But you still have 150 horsepower.
The engine mount is a 20" which was the way Lew Stolp designed it but this leads to 136 lbs on the tiny Scott 3000 tailwheel without anybody in the airplane. Stardusters developed a well deserved reputation for seeking the runway edges just about any time they were moving when set up with this geometry. Present practice is a 26 inch mount.
This $10,000 airplane is really a $30-$35,000 airplane. Even if the engine doesn't grenade on the way home I'm not going to be happy with the length of the mount and the ground handling issues. Raised up for level flight the weight on the tail is 90 lbs. It should be around 70.
And it's only got 150 horsepower.
I almost fell in love. I'm going to sleep on it overnight but right now I'm in decline mode. The quest continues.
EB
. If you can take a piece of advice from someone who's lost their !(#$* mind more than once over winning and losing that game....
