YB,
If you can believe it the "trashe" originally was fielded without WSPS, wire strike protective system and the original performance planning charts did not include the WSPS. there was something like a .1% increase in flat plate drag with the WSPS. One of the favorite things to check on checkride day was to see if you computed for the increase in drag. It wasn't enough to measure on any of the cockpit gauges, but you were wrong if you didn't compute it.
My unit had two wire strikes before it was installed, both at Fort Hood Tx. The first one was at night when the pilot hit one of the BIG power transmission cables that are attached to those towers that go cross country. Well the wire tore off the nose of the aircraft which includes both the TADS and PNVS "night vision systems" Dan Craytor "the pilot" did what anybody would have done and landed immedately. Problem is that that he flew through two more sets of wires on they way down.
It was a long time before that airplane flew again.The second one was when the unit commander hit a wire that wrapped around the gun, pulled the pole half way out of the ground, then broke it off and drug it a couple of hundred yards before the wire broke.
