Throttle on flap johnson bar, like collective?
I was just thinking after the go around talk, has anyone ever made a second throttle on the johnson bar, like what you see on a helicopter, could come in handy for more precision work
- Retired
1678
I get the throttle modulation on landing (a must for precision) but have you ever found a need to modulate flaps (other than dumping them) on landing?
Rob offline
1589
Pretty rare, however on one river I’d land on the winds would bounce off the trees in odd ways, on a few occasions I’d reduce flaps to stop a float and then have to add the right back to cushion the landing. But for most of the time as you said it’s just a dump, I’ve also wondered if anyone ever made a auto dump tired to weight on wheels?
- Retired
1678
Know a couple cubs with a dump switch on the stick, but none tied to a squat switch. That would be cool, and easy, but might make for an interesting go around if you let the wheels touch
Rob offline
1589
Rob wrote:Know a couple cubs with a dump switch on the stick, but none tied to a squat switch. That would be cool, and easy, but might make for an interesting go around if you let the wheels touch
Cubs get all the fun toys
- Retired
1678
Not quite the same, but I've seen rock crawling rigs with a bicycle brake handle mounted to the shifter, hooked to the throttle so you can have feet on brakes and clutch and hand with throttle when crawling.
Can't really see the need on a flap handle.
If I remember right, the PA18 flap dump handles I've seen were pneumatic or hydraulic cylinder with an electric button on the stick grip.
PilotPeat offline
65
- Aircraft: Cessna 172
PilotPeat offline
65
