Tie Downs For High Sierra
Which ones seem to work best on the dry lake?
lefoy84 offline
81
Flyties.
www.flyties.com Small and compact to pack away. Yet they hold up to 50 knot winds. Don't forget to bring a hammer.
DoubleSixX offline
7
- Aircraft: 182
Sun Jul 28, 2019 10:45 am
My FlyTies held (barely) during the great windstorm of 2017 at HSF.
3263
- Aircraft: 1957 C-180A
DoubleSixX wrote:Flyties.
http://www.flyties.com Small and compact to pack away. Yet they hold up to 50 knot winds. Don't forget to bring a hammer.
For my Flyties, I use as a hammer an old Vaughn drywall hatchet, with the serrated striking head. I had the blade professionally sharpened, so now it's still a good hammer but also a good camp hatchet. I tried a couple different hatchets first but they made crappy hammers, this one swings and strikes like a good hammer should, old carpenter here so pickier then most.
4197
I'm really sorry but I think all those systems are marginal at best.
For the windstorm in 2017 I had two 18' lengths of rebar on each side, but more importantly had the plane orientated to take the wind from an aft quarter. Nothing moved but last year I took two 24" lengths of angle iron with an eye welded on the end. Hammered in with an axe, I had to dig them out. The desert allows you to just keep driving them in. I used a 5lb axe.
You are really not going to care how slick they look or how light they are when your plane is tumbling down the playa.
My 2c.
1269
daedaluscan wrote:For the windstorm in 2017 I had two 18' lengths of rebar on each side
Charlie, how did you carry two 18 foot lengths of rebar in your 170!
3263
robw56 wrote:daedaluscan wrote:For the windstorm in 2017 I had two 18' lengths of rebar on each side
He taped one to each leading edge of the wings, a bit nose heavy bet he "got er done".
2093
Yeah, I meant 18". Ha ha!! I may be paranoid but I'm not crazy.
1269
latest extended baggage stc!
soaringhiggy offline
711
48 Stinson 108-3
Mon Jul 29, 2019 11:09 am
My plan is to use 18" lag bolts with a tie down plate. An 18V impact will get them into the ground no problem. Easy removal too.
hamer offline
231
Mon Jul 29, 2019 12:26 pm
I once observed the Army tying L-19s down using rods about 24 inches long with duck bill anchors which could be unscrewed, leaving only the duck bill anchors behind. Any one ever seen these?
bush master offline
108
