182 STOL driver wrote:182 STOL driver wrote:I make my own back country tiedowns . Easy with a lowes or Home depoet in area. Or send me 40 bucks and I'll make them up for you. Go to Lowes or such and get 3 concrete stakes I think there about 18" long about 1-1/2" wide by 1/4 -3/8 " thick. Go to hardware section and buy some of those 3 inch carabeiers with screw together lock. Go to rope section and get some 35 ft. of 5/8" nylon rope -head for home (don't forget a 1/2 " drill bit ) ----- go out to your trusty "man cave" and drill your concrete stakes center mass 1-1/2" from blunt end (for your carabiners) I cut 2 sections of the rope 14 ft. and burn the ends with lighter and crimp with a pair of pliers . Short section is for tail tiedown . 3-5 pound sledge with tiedowns at 30 degree outboard angle for mains and tail should do fine >drive stake into groind 1/2 to 2/3 . Bang side to side to remove . Mine went all over and worked real good. I have 4 sets down at ranch that have held airplanes down during 60 knot winds. Weigh about 3-4 lbs rolled up in back of baggage compartment .
I drive these tiedowns in rocky soil like in my little picture near my "182 Stol Driver " -used them in Idaho last summer ,Austin ,Nevada flyin and out at Grand Canyon >>> may or may not be worth 40 bucks to you but they do work under extream conditions.
We tried a test of tiedown strength -these above I made will pull bumper off car before they loosen up. A forklift (6 ton) will just barely move them out of the ground with a straight pull .Ropes or chains will fail first .Come on down to AZ50 (Triangle) and give them a pull . Stakes are about 2 bucks a piece -clasp another 3 bucks a piece ,rope is $1.50 a ft. --- time to make up a set about a hour.
