I'm no expert, but I fly with other airplanes a couple times a week. Here is a few things that are helpful:
-Know the capabilities of the other aircraft and pilot/s. Get a feel for the habits and judgement of the other pilot/s before you jump into tight formation. Don't take anything for granted until you really get to know the other pilot. Communication is key.
- Brief your flight beforehand.
Discuss who will take lead. If both pilots have similar experience/knowledge of the area it is common to put the slower airplane in the lead. This way the lead can fly at normal cruise or maneuvering speeds, and the trailing plane can catch up or slow down as necessary. Otherwise, the pilot with more knowledge of the area/mission is a good choice. If you switch leads during the flight make sure it is communicated.
Discuss communications and frequencies. Consider a plan for loss of communication.
Discuss the responsibilities of each pilot. Usually the lead will make all CTAF and ATC calls, and be responsible for when to switch frequencies. Lead will communicate intentions, turns, heading changes, hazards to the others. Lead needs to be more vigilant watching for other traffic and obstacles as a good portion of the wing man's attention will be focused on the lead plane. Lead needs to be predictable, i.e. avoid sudden unexpected maneuvers. Wing man's job is to keep the plane ahead in sight, and avoid hitting the plane ahead. Keep the lead informed of your relative position, let lead know you are out of his way if he needs to maneuver, position yourself to the outside of turns when flying close. Consider wake turbulence coming off the other plane. Avoid over running, or "boxing in" the lead plane. Besides pulling power, you can always make S turns, or climb to slow down. Besides adding power, you can cut corners, descend, or just ask the lead to slow down if you need to catch up.
Discuss take off and join up plan. If flying close formation we will take off side by side, staggered with the trailing plane on the outside of the crosswind turn. Otherwise the lead plane takes off and makes a shallow climb and turn that allows #2 to catch up by climbing steeper and cutting the corner.
Discuss route of flight and any cautions such as wires, towers, airspace, TFR's, etc.
Discuss the destination/s, plan for landings, and any cautions at the destination airstrip. Landings can be made side by side staggered (if the strip is long and wide) or spaced out (#2 extends downwind). Other options are #1 lands, and #2 makes a low pass and go around, or #2 circles until #1 gives the all clear. #1 lands midfield, #2 lands on the numbers.
Radio call for 2 ship flight: just add "flight of two" after your normal call sign. If you split up before entering the pattern (or on take off), then make your calls individually.
If you get separated, stagger your altitudes, and head for a known location/landmark. Faster plane can fly a curved course to allow the slower to catch up.
Be predictable, communicate, and keep situational awareness. Flying with other planes is a blast, and can be much safer in some situations, such as exploring remote areas. Plus you always have someone to try the landing first!
CFOT on Thu Jul 11, 2019 2:53 pm, edited 1 time in total.
