Backcountry Pilot • Tips on flying the Alcan through Canada
7 postsPage 1 of 1
I've got a couple questions for those who have made the trip. First question is, I've got 3in numbers, should I tape temporary 12in numbers with tape? I know you have to have 12in numbers for border crossing, but do they even check for that? Second issue is carrying rifles through Canada. I have the forms filled out for the Non-resident temporary firearm license application, are there any tips as far as carrying rifles through? Any tips are greatly appreciated.
N300RE offline
Aircraft: C-185,PA-30, PA-24, PA-28
Re: Tips on flying the Alcan through Canada
You don't need 12" numbers unless you are going to fly through an ADIZ (off the coast aways). Can't help you on the rifles.
Mark J
marcusofcotton offline
Make sure on the firearm application that you check the box which says "protection from wildlife".
I have had no trouble taking a rifle.
When are you going ? I am head up again from Kansas in about 3&1/2 weeks .
Doug
brown bear offline
Don't use the Scobey boarder crossing....the Canadians are friendly.....while they search through everything. Three maybe four aircraft per year use the full growth grass strip. I wonder if it ever gets mowed? Flew up the prairie to Fort Nelson..... Then followed the AlCan.... Sort of.
Mark M.
Platinum Ak
m_moyle offline
Aircraft: Piper PA 20
brown bear wrote:I have had no trouble taking a rifle.
Doug
I plan on going up in a week, and planning on clearing customs at Letherbridge AB.
N300RE offline
There is a sleeping room , shower, and car at Cutbank MT. ( KCTB } { http://cutbankairport.org/} You will want to call ahead if you will be there after hours. Also , 24 hr fuel and US Costoms
Doug
brown bear offline
7 postsPage 1 of 1
