Can anyone explain what the numbers before the wheel size mean.
Like 8:50x6 what does 8:50 mean
or
36:00x51 what does 36:00 mean (yea, I know it's big)
thanks
. The 8.50 relates to the tire diameter. Although, it doesn't appear to be an exact science. An 8.50 in one brand of tire will usually be a different diameter than an 8.50 of another brand tire. But the 8.50 will always be bigger than a 8.00 which is bigger than a 7.00, which is bigger than a 6.00, etc.
UtahMaule wrote:Can anyone explain what the numbers before the wheel size mean.
or
thanks
kevbert wrote:UtahMaule wrote:Can anyone explain what the numbers before the wheel size mean.
or
thanks
Well, if you were to change the colon to a decimal point (i.e., 8.50), it would mean the cross-section width (not diameter, not the sidewall height, not the aspect ratio as some people claim) of the tire. And, of course, as you noted, the second number is the diameter of the wheel.
If there are three numbers (i.e. 36x13x6) then first is tire diameter, second is cross-section width, third is wheel diameter.
mr scout wrote:I didn't see anyone claiming anything
Jr.CubBuilder wrote:UtahMaule wrote:So on a 36:00x51 or 36.00x51 the width of the tire is 36 inches?
On larger tires I see it with a : not a . has the meaning of that number changed or . means : ?
That's an imaginary tire (?) but that sizing nomenclature would fit the modern convention where 36 is the diameter in inches, and 51 is the width in inches. Usually that would be followed with the wheel size like -15 for example, so what you suggested would show up in the catalogue as 36x51-15 and it would be 36" in dia, 51" wide and fit on a 15" rim which would make great paddle tire for the sand dunes.
Since Wup makes his own tires for unique applications he gets to just call them whatever he wants.
By the way Wup if you have a surplus of 26"BWs I think a pair of those would be perfect for the old 170. Let me know if you have a sale
