TIRES
** I am not lazy, and did try searching data base for this before posting **
Just pulled the trigger on Airglas Nose Fork for my 1958 Cessna 172. ( Jared P is responsible for this and impending divorce if my wife sees how much I have just spent !).
Now need help on tire selection -
Am used to having Air Hawks on my 172 and on previous 150.
Am going 8.50 X 6 on Mains, 8.00 X 6 on Front.
Good Year or Air TRAC's??? Other suggestions??
rodhilton offline
43
- FindMeSpot URL: https://share.delorme.com/RodneyHilton
- Aircraft: 1958 Cessna 172
C-FKJJ
I would use the smooth Desser tire on mine!
5186
I would also do the smooth Desser 8.50s (actually I did). They're the softest and lightest 8.50s you can get. And no tread to throw rocks. They also make a smooth 8.00 that you can put on the nosewheel.
3263
- Aircraft: 1957 C-180A
I put the super hawk 8.50 on the mains and the 8.00's on the nose. I'm happy with the combo!
jaudette offline
617
- Aircraft: Husky A-1B
Vans RV-7a
You're welcome for the divorce
I plan on putting the smooth desser 8.50s and 8.00 on mine . Wish the would have been available when I purchased. I believe they're about 4 lbs ea. Lighter than the goodyears. I believe this is what crazyivan put on his 182 recently
Jeredp offline
625
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 7NYN40QT2I
- Aircraft: Cessna 172
Jeredp wrote:You're welcome for the divorce
Yeah we did. And I put them on my dads 172. His are holding up good. They are only a pound heavier than 6.00's
Tom offline
791
- Aircraft: PA-18 7EC C-172
Dresser smooths look good. looks like 5 lbs difference from the goodyears according to the websites. I have the goodyears on mine, bought the complete package from Todd at Hitchcock. I fly 50/50 asphalt and grass, the goodyears are holding up really well. I wonder where the weight savings is mainly in the dressers? If it is 5 lbs of tread rubber, might not be such a good deal if you still pound pavement a good portion of your time.
Mark Y. offline
440
- Aircraft: Cessna 182B
Just curious... do smooth tires on the nose track any differently on a 172 or 182 than tires with tread?
PapernScissors offline
419
PapernScissors wrote:Just curious... do smooth tires on the nose track any differently on a 172 or 182 than tires with tread?
My experience, no. The reason for tread on airplane tires is solely to displace water into the tread grooves to prevent hydroplaning on asphalt or concrete. The only other purpsoe tread serves is to throw pebbles on the tail an belly.
Jeredp offline
625
Jeredp wrote:
... The reason for tread on airplane tires is solely to displace water into the tread grooves to prevent hydroplaning on asphalt or concrete. The only other purpsoe tread serves is to throw pebbles on the tail an belly.
Hadn't thought of the 2nd purpose.
419
jaudette offline
617
Vans RV-7a
I am leaning towards that same set up.... majority of my flying is off of hard surface.
Trying to figure out how the AIRTRACS would measure up endurance wise against the AIRHAWKS.
rodhilton offline
43
C-FKJJ
I put the smooth dessers all the way around and love them. Run 12 psi
88Echo offline
73
- Aircraft: 1959 Cessna 172
Sun Sep 17, 2017 12:02 pm
This has nothing to do with 172s I know but it's a convenient place to ask; whats the name of that bush type tire that's not an AK bushwheeels? Isn't that a Desser?
Answered my own question.
https://www.desser.com/pc_combined_resu ... pt5~Tundra)&search_keyword=Tundra
As you were.
Mister701 offline
2134
- Aircraft: Rans S7LS
I recently put Good Year 26" tires on our Superhawk and they seem to do real well. They hold up well on asphalt and are great in the back country. Here is a picture of ours on our 2,200 strip in the Wrangell Mountains:
Nizina offline
499
Nizina
Ended up going with the Good Years... wow what a difference these will make. Install next week. Thanks for everyone's input.[emoji1303][emoji1063]
Rod Hilton
Kincardine, Ontario, Canada
C-FKJJ
Tapatalk Pro
rodhilton offline
43
C-FKJJ
